    Error: Heater 0 fault: temperature rising
    • yagodajm
      yagodajm last edited by
      Hello all, I just upgraded my duet 2 maestro from firmware 2.0 to 3.1. I used the need reprap on-line configuratior. I finally got everything working except the hot bed, it turns on and I get this error "Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7c/sec". Everything was working great with firmware 2.0, but now I just get this fault. I am not sure what is going on, my hot end works great. Here is the output from my config file.
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 09:32:59 GMT-0500 (Central Daylight Time)
      M550 P"My Printer" ; set printer name
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P0 V30 ; Stealthchop2 till about 150 mm/sec
      M569 P1 S1 ; physical drive 2 goes forwards
      M569 P1 V30 ; Stealthchop2 till about 150 mm/sec
      M569 P2 V30 ; Stealthchop2 till about 150 mm/sec
      M569 P3 V30 ; Stealthchop2 till about 150 mm/sec
      M92 X80.00 Y80.00 Z400.00 E90.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X300000.00 Y300000.00 Z6000.00 E216000.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z15.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X200 Y200 Z200 S0 ; set axis maxima
      M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:200 Y15:195 S20 ; define mesh grid
      T0 ; select first tool
        Have you tried PID tuning the bed heater yet?
        • yagodajm
          @Phaedrux said in Error: Heater 0 fault: temperature rising:
          PID tuning
          Thanks for the input, everything is working now.
