Script execution problem after printing
Good afternoon! Meet the new user
Today I installed Duet.
I ran into a printer behavior issue after printing.
I wrote a small script.========================================== M104 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G92 E0 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle to release some of the pressure G1 Z+0.5 E-3 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more M107 G1 Z5 F500 G28 Z0 G28 X0 Y0 ;move X/Y to min endstops so the head is out of the way M84 ;steppers off G90 ;absolute positioning ============================================
I donβt understand why the Duet ignores line 5, 7 and 8
The duet first parks the X and Y axes and only then Z
I want the opposite!
even t if I delete lines 8 and 9 the Duet still parks the X and Y axes, the Z axis does remain not parkedI do not understand why this happens, please help me understand
You might need to spend some time reading up on each of the commands used.
e.g.
https://duet3d.dozuki.com/Wiki/Gcode#Section_G28_Home
"The X-Z parameters act only as flags. Any coordinates given are ignored."G92 E0 ;relative positioning
No, it just sets the E position to zero
so, your subsequent commands are presumably still in absolute mode.You need G91
Probably can't happen if X/Y end stops are zero (can't move to -20).
Thank you, could you tell me how I should fix my script?
If you describe your printer (corexy, delta, cartesian?) and describe what you want to do, then we can help.
i have corexy
my table (Z-axis) rises and falls
I fixed the script like this, in my opinion it works!============================ M104 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G92 E0 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle to release some of the pressure M107 G91 G1 Z+0.5 E-3 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more G1 Z5 F500 G90 G28 Z0 G28 X0 Y0 ;move X/Y to min endstops so the head is out of the way M84 ;steppers off G90 ;absolute positioning ======================================
sorry my bad english, it's Google's fault
G92 E0 ; set extruder to 0
M83 ; set extruder to relative movements
M107
G91 ; relative movement
G1 Z5 F500
G90 ; absolute movement
G28 ; home all axis
M84 ;steppers off======================================
@Phaedrux Thanks
