    Heated bed - quick question
    • Harryniceundefined
      Harrynice
      Hi all - wanted to ask for a quick bit of advice about my heated bed.
      I am (for the moment) using a Geeetech superplate which can be set for either 12v/24v with a quick solder job. I have a 24v mean well sp-320-24 power supply.
      I need to know whether to set the heatbed for 12 or 24v
      I have read through 'choosing a bed heater' on the wiki, but I don't understand it all very well and have not come to any conclusions.
      Can someone please advise which voltage I should set on the bed please?
      Dougal1957undefined 1 Reply Last reply Reply Quote 0
      • MauriceMundefined
        MauriceM
        because you have a 24V PSU you should go with the 24V, otherwise your Bed will break. Also the amps will cut in half. which is definitely better.
        • Dougal1957undefined
          Dougal1957 @Harrynice
          @Harrynice it should be set to the same as your Vin if you are using the onboard Bed mosfets
          • aidarundefined
            aidar
            If you have 24v power supply, then of corse heated bed has to be set to 24v also.
            It will be good to know how powerful your heater is?
              Harrynice
              Thanks all, I shall set it to 24v.
              This is the bed I am using at the moment, but I am about to start building a hypercube evolution so will need a 300x300mm bed soon.
              Anyone have any recommendations for a good one?
                @Harrynice said in Heated bed - quick question:
                There are many good discussions already if you search. Here's one: https://forum.duet3d.com/topic/8649/need-advice-on-new-heated-bed-aluminium-plate?_=1591561293520
