    An AJAX error has been reported.
    • sigourosandreas
      sigourosandreas last edited by
      I have just received my board (duet wifi with antenna) and was trying to connect to it.
      I have done all the steps in the "1.) Getting Connected to your Duet" and I have connected to DWC but I think there is a problem with this board. I still have the board connected with the USB cable for power. I have not powered it from the printer yet.
      When connected to DWC, I go to settings and then to configuration files, but it just writes "loading", and never loads the files to configure them.
      I then try to upload files and it gives me this error:
      "An AJAX error has been reported, so the current session has been terminated.
      Please check if your printer is still on and try to connect again.
      Error reason: Unknown message type or not authenticated"
      I have changed SD cards in case of it was damaged but still the same.
      What should I do?
        What versions of RepRapFirmware and DuetWebControl are you using?
        • sigourosandreas
          Hi dc 42,
          As the DWC writes:
          "Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet
          Firmware Version: 2.05.1 (2020-02-09b1)
          Web Interface Version: HTML: 1.11
          Web Interface by Christian Hammacher
          Licensed under the terms of the GPL v2"
          I do not know what DWC version I use. The standard I think. This oneis taken with print screen.
          Thanks in advance for any help.
            Please update your DWC version as it is incompatible with your firmware version.
            https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
            You may have to extract that zip file into your /www folder manually to get it up to date.
              dc42 administrators @sigourosandreas last edited by
              @sigourosandreas, if you go to the Settings page you will find the DWC version displayed there. You can use version 1.22.6 or version 2.0.7.
              • sigourosandreas
                I did what you said. It is working now.
                Thank you for the excellent support!!!
