Ethernet connection not seen in DWC or DM
IS there code for finding out what is stopping the connection so I can fix it?
The easiest way is to install Wireshark on your PC and use it to log the traffic between the Duet and your PC. However, I think your SD card files are not set up correctly.
What folders on the SD card do the first and second listings in your image show?
Anyway, it appears that you don't have DuetWebControl 1.15a extracted correctly onto your SD card, because even if the second listing shows the /www folder, the files are wrong. I suggest you delete your existing /www folder on the SD card, create a new one, then copy or extract the contents of DuetWebControl-1.15a,.zip into it. Your SD card /www folder should then look like the image I posted earlier.
Success! Now I can pull my hair out tuning it, LMAO!
