    Reliable SD Card source ?
    336
    • A Former User?
      A Former User
      I have noticed a few SD card issue threads.
      And I have recently been fighting more than a few what turned our to be SD card issues.
      I generally dont buy SD cards online for fear of getting cheap Chinese fakes, I try to buy locally from somewhat reputable electronic outlets.
      Buying either "Scandisk" or "Transend" 8gb cards
      And as I have more than a few printers I always have at least 10 spare cards, and I always do a full overwrite format.
      But recently I suffered a few failed prints with a printer acting just plain weird, stopping mid print or failing to home properly, all of which i have replaced the SD card on and even then a brand new SD card has sometimes turned out to be faulty, that threw me and made me look for problems that weren't actually there.
      I keep a master back-up of all my printers SD cards on my PC so I revert to the master instead of trying to copy possible corrupt file on to a new card.
      And as cards a generally quite cheap any suspect card automatically gets snapped in half and binned, it's just not worth it.
      So where are people generally getting good quality reliable cards ? brand, size etc etc?
      deckingmanundefined zaptaundefined 2 Replies Last reply Reply Quote 0
      • deckingmanundefined
        deckingman @A Former User
        @CaLviNx I generally buy SanDisk and get them via Amazon but I don't know if that's an option in your part of the world.
        • zaptaundefined
          zapta @A Former User
          @CaLviNx said in Reliable SD Card source ?:
          Is your SD in a heated chamber by any chance?
          • A Former User?
            A Former User
            SLC is "always" an option for reliability, but given the price is probably in the 10x range, you can break a few cards before breaking even.
            But if reliability is key, then it might be worth it non the less. Other than that try a card rated for application use (A1) and the bigger the card the more you'll spread the write wear before running into issues; on the other hand if the issue is environmental like zapta is suggesting then the industrial cards will also help if the issue isn't the socket.
            zaptaundefined 1 Reply Last reply Reply Quote 0
            • piperswundefined
              pipersw
              SanDisk SD, SDHC, microSD and microSDHC memory cards are capable of withstanding operating temperatures from -13ºF to 185ºF (-25ºC to 85 ºC), so no issue inside an enclosure
              • zaptaundefined
                @bearer said in Reliable SD Card source ?:
                It's interesting that SanDisk represents MLC (4 levels per cell) as high reliability and industrial, because it can get even denser with 32 levels per cell.
                https://en.wikipedia.org/wiki/Multi-level_cell
                This company sells industrial SLC cards for a reasonable price but never heard of them before so don't know how good they are.
                https://www.amazon.com/ATP-2GB-Industrial-Grade-40C/dp/B076PNFYVR
                • A Former User?
                  A Former User @zapta
                  @zapta
                  No, on my two with chambers I have the electronics under the chamber insulated and a constant cold airflow, but temps are generally hotter here (Cyprus) so that might be a factor to investigate, thanks to all for the suggestions
                  • A Former User?
                    @zapta said in Reliable SD Card source ?:
                    i'd say higher density is worse as a single failure will destory more data, and more data possibly sharing erase operations* where the SLC still has MLC beat by an order of magnitude (but admittedly I've not been keeping up with the development on that front)
                    *) but if erase happens on a page by page basis then maybe not a big factor unless cells span pages.
                    • A Former User?
                      A Former User
                      Thanks for all the helpful comments.
                      I have bought some ScanDisk Industrial cards to see if they stand up any better.
                      • piperswundefined
                        pipersw
                        You could try a Sandisk Extreme III, it handle 85°C
