    Testing filament sensor on RRF3
    465
    • gnydickundefined
      gnydick
      I'm running the first stable release of RRF3, and I can't get the filament sensor to work as expected.
      If I just unplug the sensor, the print pauses, but if I cut the filament and it runs out, nothing happens.
      I'm running A DIY encoder wheel w/optical sensor.
      The documentation for managing pins for RRF3 is a bit light. As far as I can tell, I don't need an M574 to setup the endstop since I'm just using its pin.
      M591 D0 P7 C"duex.e2stop" S1 E50 L1.739 R50:150
      M581 P"duex.e2stop" T1 C1
      • A Former User?
        A Former User @gnydick
        @gnydick said in Testing filament sensor on RRF3:
        probably a good idea to move on from the first stable (3.0) to the latest (3.1.1), lots of issues fixed since then
        • fractalengineerundefined
          fractalengineer
          What does the console returns when you send M591 D0 during a print
          Railcore II ZL
          • gnydickundefined
            gnydick
            M591 D0
            Extruder 0 has no filament sensor
            So I set it up again.
            Error: unsuitable pin
            But other times it works it creates the sensor. I don't know what's going on.
              droftarts administrators @gnydick
              @gnydick Pin names for Duet 2 Wifi are here: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
              Do you have a Duex connected? If not, and you're plugging the sensor into the expansion header, try using "exp.e2stop" instead.
              gnydickundefined 1 Reply Last reply Reply Quote 0
              • gnydickundefined
                gnydick
                I have the duex. Looks like since I only have E0 and E1, I can't use the E2 stop. When I switched it to "e0stop" it's working. Can the pins be reassigned so I can use the header on the duex?
                • gnydickundefined
                  gnydick @droftarts
                  @droftarts so far, it's triggering even if the wheel is turning. It says this
                  Pulse-type filament monitor on pin e0stop, enabled, sensitivity 1.739mm/pulse, allowed movement 50% to 150%, check every 5.0mm, no data received
                  fractalengineerundefined 1 Reply Last reply Reply Quote 0
                    fractalengineer @gnydick
                    @gnydick good, now that it's plugged proper, please update the config to the following: M591 D0 P7 C"exp.e2stop" S0 E50 L1.12 R50:150 A1
                    S0 disables monitoring so that it won't interrupt the print
                    and A1 measures only during extruder moves.
                    Then could you run a print, run a couple M591 D0 during the print and share the returning messages here?
                    We're looking for the measured sensitivity for calibration
                    Railcore II ZL
                    • gnydickundefined
                      gnydick @fractalengineer
                      @fractalengineer thanks!
