Z-steppers home direction wrong??
I am busy with the BLV printer and Duet2Wifi setup: I can home X & Y as.
But the Z-as home direction is not correct it lowers the bed (and the ir-probe is attached to the heatend-fan unit.. so, it must go upI have tried to change the direction, same results. (Using online configurator)
Don't want to change the wires.any idea's ?
can't send the config-files here...
We can not help if you can not post config files. What we need is config.g (at least endstops and probe section of it) and homeall.g and homez.g
Fixed, the new config file was not uploaded to the sdcard 😀
