    More than five external drivers?
    422
    • misanundefined
      misan
      I wonder if it is possible to have more than five external stepper drivers. I am currently using the Duet 2 Wifi but I could move to another model.
      My guess is that it might be possible with Duet3 if I use CanOpen divers but any help is appreciated.
      Unfortunately, our application requires much beefier motors so the built-in drivers are just not enough so we need to go to external drivers for all of them.
      Thanks a lot,
      misan
        You can connect another 2 external drivers to the CONN_LCD connector. The signals levels are 3.3V so you will almost certainly need to buffer and level shift them to 5V. https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
        misanundefined 1 Reply Last reply Reply Quote 0
        • misanundefined
          misan @dc42
          @dc42 Great, I have not seen that link before, I missed it 🙂
          OTOH, would there be an EtherCAT or CANOpen solution compatible somehow to extend the number of axes further?
            dc42 administrators @misan
            This will be in production soon https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD
            • misanundefined
              misan
              Brilliant, I will stay tuned.
              • misanundefined
                misan @dc42
                @dc42 Are these Duet_3_Expansion_1XD available now? If not, is there an ETA?
                Thanks,
                misan
                • T3P3Tonyundefined
                  T3P3Tony administrators @misan
                  @misan they are at the factory! I will make an announcement once we have some in stock.
                  www.duet3d.com
                  • misanundefined
                    misan @T3P3Tony
                    @T3P3Tony Ok, thanks a lot for the update.
