    RRF2 to RRF3 BL Touch problem
    • GeorgeM
      GeorgeM last edited by
      I haven't used my printer for about 6 months and am now getting back into it. (amazing how much I have forgotten about the workings of the Duet in that time!)
      Anyway my current working configuration is 2.0.5.
      I got another sd card and copied my good v2 configuration onto it. I then proceeded to upgrade to first 3.0 and then 3.1.3. After comparing my v2 config with v3 config I strted it up. X and Y home fine. However the pin on my BL Touch will not deploy. When I turn the machine on it does do the self test of going up and down twice and then retracts and the light comes on. I am pretty sure I copied what others have used for the BL but something has to be incorrect. Here is my info.
      By the way I have tried both C"^zprobe.in" and C"zprobe.in"
      Config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 15 2020 11:14:50 GMT-0600 (Mountain Daylight Time)
      M550 P"My Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwords
      M569 P4 S0 ; physical drive 4 goes backward
      M584 X0 Y1 Z2:4 E3 ;two Z Motors connected to driver outputs A and E1
      M671 X-20:310 Y0:0 S2 ;Leadscrew at left (connected to Z) and right connected to E1) of X axis
      M350 X16 Y16 Z16 E16 U16 I1 ; configure microstepping with interpolation
      M92 X101.84 Y104.96 Z402.42 U402.42 E2892.00 ; set steps per mm
      M566 X500.00 Y500.00 Z100.00 U100.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X10000.00 Y10000.00 Z6000.00 U6000.00 E8000.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z30.00 U30.00 E120.00 ; set accelerations (mm/s^2)
      M906 X1200.00 Y1200.00 Z800.00 U800.00 E500.00 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-25 Y-15 Z0 S1 ; set axis minima
      M208 X330 Y340 Z300 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      ;M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 C"^zprobe.in" H3 F120 T4800 ; set Z probe type to bltouch and the dive height + speeds
      ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta
      parameters have been saved
      G31 P25 X30 Y-10 Z.48 ; set Z probe trigger value, offset and trigger height
      M557 X15:285 Y15:275 S20 ; define mesh grid ; define mesh grid
      M376 H10
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M563 P0 S"E3D_V6" D0 H1 F0 ; define tool 0
      Deploy.g
      ; deployprobe.g
      ; called to deploy a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Aug 14 2019 07:35:06 GMT-0600 (Mountain Daylight Time)
      M280 P3 S10 I1
      Retractprobe.g
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P3 S90 I1
      Home.g
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Aug 14 2019 07:35:07 GMT-0600 (Mountain Daylight Time)
      G91 ; relative positioning
      G1 Z5 F6000 H2 ; lift Z relative to current position
      G90 ; absolute positioning
      G1 X153 Y158 F6000 ; go to middle
      G1 H2 Z5 F100 ; lift Z relative to current position
      I would appreciate any advice
      Thanks
      Phaedrux JoergS5 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @GeorgeM last edited by
        @GeorgeM said in RRF2 to RRF3 BL Touch problem:
        Deploy.g
        ; deployprobe.g
        M280 P3 S10 I1
        Retractprobe.g
        ; retractprobe.g
        M280 P3 S90 I1
        P3 needs to be P0
        In RRF3 we use the M950 command to create the servo control pin. You have M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch The S0 means servo number 0. The M280 command for deploy and retract needs to target that servo number.
        • JoergS5
          JoergS5 @GeorgeM last edited by
          @GeorgeM IMHO the filename for deploying is deployprobe.g, not deploy.g.
          • GeorgeM
            Thank you so much. That worked. And your explanation was very helpful.
