    thermistor reading too low.
    • Colten
      Colten last edited by Colten
      I upgraded to a Duet3 from a Duet2 running RRF3. Everything was working as it should with the Duet2. Since the replacement of the board however, I'm having a odd issue with my thermisistor's. They are reading 15 degrees too low. Right now they should be reading 20 degree's which is the temp in my shop. They are instead reading 5.4 degree's.
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 R4700  A"Bed"; bed thermistor V3
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 R4700   A"Hotend"; e0 temp sensor V3
      M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet"
      M308 S3 P"drivers" Y"drivers" A"Drivers"
      M950 H0 C"out0" T0 ; heater 0 uses the bed_heat pin, sensor 0
      M950 H1 C"out1" T1 ; heater 1 uses the e0_heat pin and sensor 1
      M140 H0																		  ; Enable bed heater
      M143 H0 S120        ; Set temperature limit for heater 0 to 120C
      M143 H1 S340        ; Set temperature limit for heater 1 to 300C
      ; RRF V3
      M307 H0 A46.4 C211.7 D14.8 S1.00 V24.6 B0 ; bed V3
      M307 H1 A230.7 C115.6 D4.9 S0.90 V23.9 B0  ;; V3 e3d 24v hotend
      If I change the R value to about 2200 or so, I can get the temp in range. Same with playing with the H value. This is not ideal however.
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @Colten last edited by
        @Colten said in thermistor reading too low.:
        just remove the R parameter, and it will default to the correct value for the board, which i do believe is 2200.
        • Colten
          perfect. that fixed it. I believe the duet2 uses 4700 as the default. I believe this should be documented somewhere, but I was unable to find it.
          • A Former User
            it is, or was refrenced in the old M305 command, but not the new M308 command.
            • A Former User
              A Former User @Guest last edited by
              @bearer said in thermistor reading too low.:
              probably something @Phaedrux will sprinkle some magic dust on?
                Phaedrux Moderator @Guest last edited by
                @bearer consider it sprinkled.
