Sanity check on Fan setup for laser
  • For the last two days I have been fighting getting my laser to work with my Duet2 WiFi.
    Now I am wondering if I have a bigger problem with my fans.
    I just converted from 2.0.5 to 3.1.1. I thought things went well overall - even printed a couple of items. But then looking at it more critically I find that the Fan1 (extruder heat sink fan) is on all the time rather than when temp reaching 45 as it should. Fan 0 (parts fan) is not coming on at all even though the slicer calls for it to come on at layer 3 and increase to higher rpm at layer 6. And of course my laser connected to Fan2 does not adjust via laser commands (M3 Sxxx) or turn on or off (M3 S0 or M5). I could really use some help in diagnosing this. I haven't used my printer for about 6 months so I'm really re learning a lot of this. Anyway here are some of the info:
    Power supply 24 volts
    Duet 2 WiFi 1.02
    Firmware 3.1.1
    Here is the config file
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 15 2020 11:14:50 GMT-0600 (Mountain Daylight Time)
    M550 P"My Printer" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwords
    M569 P4 S0 ; physical drive 4 goes backward
    M584 X0 Y1 Z2:4 E3 ;two Z Motors connected to driver outputs A and E1
    M671 X-20:310 Y0:0 S2 ;Leadscrew at left (connected to Z) and right connected to E1) of X axis
    M350 X16 Y16 Z16 E16 U16 I1 ; configure microstepping with interpolation
    M92 X101.84 Y104.96 Z402.42 U402.42 E2892.00 ; set steps per mm
    M566 X500.00 Y500.00 Z100.00 U100.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X10000.00 Y10000.00 Z6000.00 U6000.00 E8000.00 ; set maximum speeds (mm/min)
    M201 X800.00 Y800.00 Z30.00 U30.00 E120.00 ; set accelerations (mm/s^2)
    M906 X1200.00 Y1200.00 Z800.00 U800.00 E500.00 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-25 Y-15 Z0 S1 ; set axis minima
    M208 X330 Y340 Z300 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P9 C"^zprobe.in" H3 F120 T4800 ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X30 Y-10 Z.48 ; set Z probe trigger value, offset and trigger height
    M557 X15:285 Y15:275 P5:5 ; define mesh grid ; define mesh grid
    M376 H10
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M950 F2 C"!fan2" Q1000 ; create fan 2 on pin fan1 and set its frequency
    M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
    M563 P0 S"E3D_V6" D0 H1 F0 ; define tool 0
    Here is a pic of my fan jumpers:
    Thanks for looking
    George
  • Moderator
    The config looks ok for what you describe.
    Are you able to control the part cooling fan with the slider in DWC?
    Do you have any additional fan commands elsewhere that might be overriding what you have in config.g?
    Send M106 P# to get a read back of the current configuration for each fan.
    Can you also send M122 and report back.
    And send M98 Pconfig.g and report back with any error messages.
  • @Phaedrux said in Sanity check on Fan setup:
    M98 Pconfig.g
    Thank you for replying.
    First off I redid some of the wiring for the fans. Instead of using VIN power I am now supplying the power from a buck to reduce the 24v to 12v via the middle pin on the V Fan Jumper. I also found a loose connection on the Fan0.
    So after that Fan0 and Fan1 are working as they are supposed to. However I am back at not getting Fan2 to control the laser. Even when I hook up a simple fan it does not work. Moving the slider on the Dashboard produces nothing. And when I send m106 commands the slider moves but the fan does not. (By the way I checked with two different fans, both know to be working).
    M98 produces nothing
    Here are the m106 status
    6/17/2020, 5:41:58 PM m106 p0
    Fan 0, speed: 0%, min: 10%, max: 100%, blip: 0.10
    6/17/2020, 5:41:54 PM m106 p1
    Fan 1, speed: 100%, min: 10%, max: 100%, blip: 0.10, temperature: 45.0:45.0C, sensors: 1, current speed: 0%:
    6/17/2020, 5:41:50 PM m106 p2
    Fan 2, speed: 0%, min: 10%, max: 100%, blip: 0.10
    And here is the fan part of my config.g
    Lastly here is the M122:
    6/17/2020, 5:36:13 PM === Diagnostics ===
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-9T6BU-FG3SJ-6JKD4-3S46L-TUW7D
    Used output buffers: 3 of 24 (20 max)
    Static ram: 27980
    Dynamic ram: 93984 of which 60 recycled
    Exception stack ram used: 264
    Never used ram: 8784
    Tasks: NETWORK(ready,368) HEAT(blocked,1216) MAIN(running,1816) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:00:41 ago, cause: power up
    Last software reset at 2020-06-17 10:03, reason: User, spinning module GCodes, available RAM 8784 bytes (slot 2)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 31.8, current 36.0, max 36.0
    Supply voltage: min 23.7, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-06-17 17:35:47
    Cache data hit count 66412690
    Slowest loop: 7.78ms; fastest: 0.14ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 16.4ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 23.25ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    HTTP sessions: 2 of 8
    • WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address cc:50:e3:6a:85:90
      WiFi Vcc 3.35, reset reason Unknown
      WiFi flash size 4194304, free heap 24448
      WiFi IP address 192.168.1.73
      WiFi signal strength -67dBm, reconnections 0, sleep mode modem
      Socket states: 4 0 0 0 0 0 0 0
    I don't see where I am off.
    George
