    Pressure Advance Having No Effect?
    • GoremanXundefined
      GoremanX
      I'm trying to tune the pressure advance on my Ender 5 Pro with a new Duet 2 Maestro setup by following the guidelines on this page. My printer has a bowden setup with a tube that's slightly longer than 200mm. Extrusion is calibrated precisely at 420s/mm with a Bondtech extruder.
      I took this test cylinder and made it 50mmx50mmx100mm. Set Cura to slice it with a 6-line brim, 2 wall outlines, no infill and no top/bottom surfaces. Then I took the resulting gcode file and added M572 commands every 100 layers as so:
      M572 D0 S0
      M572 D0 S0.1
      M572 D0 S0.2
      and so on up to S0.9. I added the M572 commands immediately before the G11 command preceding each 100th layer. I'm running this test with PLA.
      Here's the resulting print (with the brim removed):
      There's absolutely NO difference along the seam all the way up the cylinder. I'm very confused. Here's the beginning of the gcode file:
      ;FLAVOR:RepRap
      ;TIME:16158
      ;Filament used: 5.17305m
      ;Layer height: 0.1
      ;MINX:82.81
      ;MINY:82.803
      ;MINZ:0.2
      ;MAXX:137.198
      ;MAXY:137.196
      ;MAXZ:100
      ;Generated with Cura_SteamEngine 4.6.1
      T0
      M190 S60
      M104 S200
      M109 S200
      M82 ;absolute extrusion mode
      ;M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
      ;M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
      ;M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
      ;M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
      ;M220 S100 ;Reset Feedrate
      ;M221 S100 ;Reset Flowrate
      G28 ;Home
      G92 E0 ;Reset Extruder
      G1 Z2.0 F3000 ;Move Z Axis up
      G1 X0.0 Y20 Z0.28 F5000.0 ;Move to start position
      G1 X0.0 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
      G1 X0.3 Y200.0 Z0.28 F5000.0 ;Move to side a little
      G1 X0.3 Y20 Z0.28 F1500.0 E30 ;Draw the second line
      G10
      G11
      M83 ;relative extrusion mode
      G10
      ;LAYER_COUNT:999
      ;LAYER:0
      M107
      G0 F9000 X90.941 Y90.595 Z0.2
      ;TYPE:SKIRT
      M572 D0 S0.0
      G11
      G1 F1800 X92.028 Y89.585 E0.04935
      G1 X93.17 Y88.634 E0.04943
      G1 X94.36 Y87.748 E0.04935
      G1 X95.599 Y86.927 E0.04944
      Here's my config.g:
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 14 2020 23:24:54 GMT-0400 (Eastern Daylight Time)
      M550 P"Ender 5 Pro"                                ; set printer name
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S0                                         ; physical drive 2 goes backwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z800.00 E420.00                  ; set steps per mm
      M566 X1600.00 Y1200.00 Z180.00 E3600.00 P1           ; set maximum instantaneous speed changes (mm/min)
      ;M203 X18000.00 Y18000.00 Z1200.00 E6000.00         ; set maximum speeds (mm/min)
      ;M201 X500.00 Y500.00 Z50.00 E3000.00              ; set accelerations (mm/s^2)
      M203 X30000.00 Y30000.00 Z600.00 E3000.00         ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I30                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X220 Y220 Z300 S0                             ; set axis maxima
      M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"^zprobe.mod"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F240 T12000               ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-43 Y-13 Z1.35                            ; set Z probe trigger value, offset and trigger height
      M557 X0:177 Y0:207 S29.5                             ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S150                                       ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092      ; configure sensor 1 as thermistor on pin e0temp
      M308 S2 P"ctemp" Y"thermistor" T100000 B4092       ; configure sensor 2 as thermistor on pin ctemp
      M950 H2 C"e1heat" T2                               ; create chamber heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                            ; map chamber to heater 2
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H-1                                     ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F0                         ; define tool 0
      ; Custom settings
      M569 P0 V46                                        ; Stealthchop2 till about 200 mm/sec
      M569 P1 V46                                        ; Stealthchop2 till about 200 mm/sec
      M569 P2 V46                                        ; Stealthchop2 till about 200 mm/sec
      M569 P3 D3 V100                                    ; Extruder in Stealthchop2
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
      And here's my config-override.g:
      ; config-override.g file generated in response to M500 at 2020-06-13 13:47
      ; Heater model parameters
      M307 H0 A404.7 C496.8 D3.0 S1.00 V24.2 B0
      M307 H1 A422.8 C91.1 D2.7 S1.00 V24.2 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      ; Enable pressure advance
      M572 D0 S0.05
      ; Firmware retraction
      M207 S4.0 F3000 Z0.1
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      Any help figuring out what I'm doing wrong would be greatly appreciated.
        Well your bowden tube isn't exceedingly long, so I think what you're seeing is a fairly decent seam. It's not going to disappear if that's what you were expecting.
        You may want to try printing a square so that you can see the effect on sharper corners as well. And also try printing some actual models of things you may actually print to see the effects on something other than a test object.
        Also, your X Y acceleration and jerk are quite low and your print speed not very high, so the effects of PA will be less apparent. It's most noticeable at high speeds.
        • GoremanXundefined
          GoremanX
          Can you tell me what you think my print speed will be based on these files? Because I'm having a heck of a time getting it to actually print at the speed I have it set to in Cura. It keeps topping out at a different number than I expect. Keep in mind that I have most of the start settings in the gcode file commented out because those were preset by Cura and seemed to be overriding my firmware settings.
            Can you post the entire sliced gcode file from cura so we can see the settings included at the end?
            You've already dealt with the most common reason that prevents cura from reaching the expected speed by commenting out those lines. So that's not it.
            What do you have the print speed set to? Bare in mind that if you're using the basic cura interface the print speed you set is a base speed that gets reduced depending on the print move (slower for external perimeters etc). So you'll need to use the more advanced settings options in Cura to see in detail what is set to what. Including un hiding some settings that are hidden by default.
            GoremanXundefined 1 Reply Last reply Reply Quote 0
            • GoremanXundefined
              GoremanX @Phaedrux
              @Phaedrux Thanks, that helped me figure it out. The "Print speed" setting in Cura is very misleading. I turned on the visibility of the wall speed and infill speed and I saw that Cura recalculates wall print speed MUCH lower than what I set in the "Print speed" field. It's ironic because I had the initial layer set to 30mm/s (which is how fast it went) for better adhesion, and then the overall print speed set to 40mm/s, which means Cura would slow everything down to 25mm/s on the second layer and then 20mm/s on every other layer instead of speeding up the way I wanted... seems really counter-intuitive.
                Phaedrux Moderator @GoremanX
                @GoremanX Cura has an abundance of tuning options under the hood, which can be very intimidating for new users so the basic interface is incredibly simplified and set to give successful if not optimal results. As with any complex software tool, you really need to research and learn and dig down deep to get the most out of it.
