Aux(bad-csum): M408 S0 R13
  • I think I've got a faulty Duet2 WiFi.
    I've been running a Chinese clone for a couple of years and it's been great.
    When you released the conditional G-Code feature in 3.01 I decided to pay the entry fee and buy a genuine Duet so that I could participate in the forum and be a part of the community.
    So far though, this genuine board has not been an easy swap. Electrically all the connections were a 10 min board swap, but the behaviour of the board has had me double checking all the connections, rewiring, rewriting the config thinking that there may be some nuances I'd missed.
    Tonight I decided to connect via USB and run the debug commands to see what it had to say. It runs fine for probably half an hour (from cold) then starts with this bad-checksum error from the panelDue. It then continues with unable to read the SD card as you can see from the code snippet below. Give it an hour to cool down and it'll run fine for another half hour. It's taken a couple of months to troubleshoot this, partly because I keep losing interest when it misbehaves for no "apparent" reason or error, debug over usb-serial was holding what I needed.
    I finally gave in and switched back in the chinese clone and without any changes to config or wiring, the board fired straight up with the SD card the genuine board said was unusable (I had tried 3 different cards during this time so it's not just a faulty card) and proceeded to print.
    Could you authorise a return so I can go back to ooznest and get a replacement board please?
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Aux: M408 S0 R11
    Daemon: skip
    Read 0 1 58500736
    Error: Cannot read file, error code 1
    Aux: M408 S0 R12
    Read 0 1 24576
    Warning: Failed to open 0:/sys/daemon.g to read, error code 1
    Aux: M408 S0 R13
    Read 0 1 24576
    Aux: M408 S0 R14
    Read 0 1 24576
    Aux: M408 S0 R15
    Read 0 1 24576
    Aux: M408 S0 R16
    Read 0 1 24576
    Aux: M408 S0 R17
    Read 0 1 24576
    Aux: M408 S0 R18
    Read 0 1 24576
    Aux: M408 S0 R19
    Read 0 1 24576
    Aux: M408 S0 R20
    Read 0 1 24576
    Aux: M408 S0 R21
    Read 0 1 24576
    Aux: M408 S0 R22
    Read 0 1 24576
    Aux: M408 S0 R23
    Read 0 1 24576
    Aux: M408 S0 R24
    Read 0 1 24576
    Aux: M408 S0 R25
    Read 0 1 24576
    Aux: M408 S0 R26
    Read 0 1 24576
    Aux: M408 S0 R27
    Read 0 1 24576
    Aux: M408 S0 R28
    Read 0 1 24576
    Aux: M408 S0 R29
    Read 0 1 24576
    Aux: M408 S0 R30
    Read 0 1 24576
    Aux: M408 S0 R31
    Read 0 1 24576
    Aux: M408 S0 R32
    Read 0 1 24576
    Aux: M408 S0 R33
    Read 0 1 24576
    Aux: M408 S0 R34
    Read 0 1 24576
    Aux: M408 S0 R35
    Read 0 1 24576
    Aux: M408 S0 R36
    Read 0 1 24576
    Aux: M408 S0 R37
    Read 0 1 24576
    Aux: M408 S0 R38
    Read 0 1 24576
    Aux: M408 S0 R39
    Read 0 1 24576
    Aux: M408 S0 R40
    Read 0 1 24576
    Aux: M292 P1
    Aux: M408 S0 R41
    Read 0 1 24576
    Aux: M408 S1
    Read 0 1 24576
    Aux: M408 S0 R43
    Read 0 1 24576
    Aux: M408 S0 R44
    Read 0 1 24576
    Aux: M408 S0 R45
    Read 0 1 24576
    Aux: M408 S0 R46
    Read 0 1 24576
    MWarning: Failed to open 0:/sys/daemon.g to read, error code 1
    Aux: M408 S0 R47        M11Read 0 1 24576        M112Warning: Failed to open 0:/sys/daemon.g to read, error code 1
    USB: M112
    Emergency Stop! Reset the controller to continue.
    ok
    Aux: M408 S1
    Read 0 1 24576
    Aux: M408 S0 R50
    Read 0 1 24576
    Aux: M408 S0 R51
    Read 0 1 24576
    Aux: M408 S0 R52
    Read 0 1 24576
    Aux: M408 S0 R53
    Read 0 1 24576
    HTTP: M999
    Aux: M408 S0 R54
    Read 0 1 24576
    [Disconnected]
    [Connected]
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet Version 3.1.1 dated 2020-05-19b2
    Cannot initialise SD card 0: Card is unusable
    WiFi is disabled.
    RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-9T6BU-FG3SD-6J9D2-3SN6M-9UJHG
    Used output buffers: 1 of 24 (1 max)
    Static ram: 27980
    Dynamic ram: 92268 of which 20 recycled
    Exception stack ram used: 272
    Never used ram: 10532
    Tasks: NETWORK(ready,1884) HEAT(blocked,1476) MAIN(running,2580) IDLE(ready,80)
    Owned mutexes:
    Last reset 00:00:09 ago, cause: software
    Last software reset at 2020-06-19 01:21, reason: User, spinning module GCodes, available RAM 7708 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 34.9, current 35.1, max 35.1
    Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
    Cache data hit count 888068
    Slowest loop: 5.45ms; fastest: 0.13ms
    === Storage ===
    Free file entries: 10
    SD card 0 detected, interface speed: 12.0MBytes/sec
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    === AuxDDARing ===
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is ready with "M122" in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 0.18ms; fastest: 0.01ms
    HTTP sessions: 0 of 8
    - WiFi -
    Network state is disabled
    WiFi module is disabled
    Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
    ok
    [Disconnected]
    [Connected]
    WiFi is disabled.
    Warning: VIN under-voltage event (9.5V)
    [Disconnected]
    [Connected]
    WiFi is disabled.
    [Disconnected]
    [Connected]
    WiFi is disabled.
    [Disconnected]
    [Connected]
  • Moderator
    Can you share your config.g please?
    Where and when was the board purchased?
    Are you running firmware version 3.1.1 right now?
  • @Phaedrux I bought it from ooznest on 12 may, here is config.g as requested, if I'm missing something obvious please point me in the right direction.
    ; Configuration file for Duet WiFi
    ;M912 P0 S-13						; Correct MCU Temp (HotEnd - MCU at room temp)
    G90									; Send absolute coordinates...
    M83									; ...but relative extruder moves
    M669 K1								; Select CoreXY mode
    M404 N1.75 D0.4						; Set Filament diameter and nozzle size
    M550 P"Duet3D"						; Set machine name
    M575 P1 S1 B57600					; Configure Speed for PanelDue
    ;M98 PCONFIGNETWORK.g				; Configure WiFi Access
    M552 S1								; Enable network
    M586 P0 S1							; Enable HTTP
    M586 P1 S0							; Enable FTP
    M586 P2 S1							; Enable Telnet
    M569 P0 S0							; Drive 0 goes backwards
    M569 P1 S1							; Drive 1 goes forwards
    M569 P2 S1							; Drive 2 goes forwards
    M569 P3 S1							; Drive 3 goes forwards
    M350 X16 Y16 Z16 I1					; Configure microstepping for motion
    M350 E16 I1							; Configure microstepping for extruder
    M92 X200.00 Y200.00 Z1600.00 E830.00		; Set steps per mm
    M203 X12000.00 Y12000.00 Z1200.00 E12000.00	; Set maximum speeds (mm/min)
    M566 X800.0 Y800.0 Z120.0 E3000.0			; Set maximum instantaneous speed changes (jerk in mm/min)
    M201 X1800.0 Y1800.0 Z240.0 E3000.0			; Set accelerations (mm/s^2)
    M204 P1200 T1800						; Set printing and travel accelerations
    M906 X1600.00 Y1600.00 E1600.00 I20		; Set motor current (mA) and motor idle factor in per cent
    M906 Z1330.00 I20						; Set motor current (mA) and motor idle factor in per cent
    M913 X60 Y60 Z40 E40					; Set motor current (%) of rated
    M917 X20 Y20 Z10 E20					; Set motor standstill current (%) of rated
    M84 S5									; Set idle timeout
    M569 P2 F5								; adjust CHOPCONF for Z motor
    M569 P0:1 F5							; adjust CHOPCONF for X Y motors
    M208 X-56.4 Y-9 Z0 S1					; Set axis minima
    M208 X211 Y286 Z200 S0					; Set axis maxima
    ; Endstops & Motor Stall
    M574 Z2 S3					; Set endstops controlled by motor load detection + direction
    M574 X1 Y1 S3				; Set endstops controlled by motor load detection - direction
    M915 P0:1 H400 S2 F0 R0			; Stall Detection for X Y Axis
    M915 P2 H400 S3 F0 R0			; Stall Detection for Z Axis
    M915 P3 H400 S3 F0 R0			; Stall Detection for Extruders
    M558 K0 P8 C"!zprobe.in" R0.5 H5 F600 T6000 S0.03 B0 A1	; Set Z probe type
    G31 P1000 K0 X0 Y0 Z-0.04								; Set Z probe offsets
    M557 X5:195 Y5:195 S19:19								; Define mesh grid
    ; Sensors
    M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 A"Bed"			; define temp sensor for Bed Core
    M308 S1 P"e0_temp" Y"pt1000" A"Mosquito" 			            ; define temp sensor for Extruder
    M308 S2 P"e1_temp" Y"thermistor" T100000 B3950 A"Bed Surface"	; define temp sensor for Bed Surface
    M308 S3 P"mcu-temp" Y"mcu-temp" A"MCU"							; define temp sensor for MCU
    M950 H0 T0 C"bed_heat"			; define bed heater
    M950 H1 T1 C"e0_heat"			; define extruder heater
    M143 H0 S140					; Set temperature limit for heater 0 to 140C
    M143 H1 S300					; Set temperature limit for heater 1 to 300C
    M140 H0							; set default Bed heater
    M950 F0 C"fan_0" Q100				; define FAN for Part cooling
    M950 F1 C"fan_1" Q100				; define FAN for Extruder cooling
    M950 F2 C"fan_2" Q90				; define FAN for Stepper cooling
    M106 P0 C"Part Cooling" H-1					; Set fan 0 Part cooling fan
    M106 P1 C"Mosquito" X1.0 H1 T45				; Set fan 1 Hotend cooling fan, above 45C
    M106 P2 C"Stepper" H3 L0 X1 B0.3 T30		; Set fan 2 Stepper Driver cooling fan based on MCU temp
    M563 P0 S"Mosquito" D0 H1 F0	; Define tool 0
    G10 P0 X0 Y0 Z0					; Set tool 0 axis offsets
    G10 P0 R140 S200				; Set initial tool 0 active and standby temperatures to 0C
    ; Automatic power saving
    M911 S23 R24 P"M913 X0 Y0 G91 G1 Z5 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    M671 X190:100:10 Y30:183:30 P0.5	; bed adjust locations and screw pitch 0.5 for G32 assistant
    ;M207 S1.5 F900						; Flex3drive G5 extruder
    M207 S1.4 F4800						; Default retraction settings
    M81									; Enable ATX buttons in DWC
    M501								; Load saved parameters from non-volatile memory
  • Moderator
    Thanks. Would you be able to post a photo of the back side of the SD card slot? Close up and well lit so that we can see the solder tabs?
  • @Phaedrux ok...
  • @Phaedrux Any news on this please?
  • Moderator
    Hi, sorry I missed your post with the photos. I suspect that it may be an issue with the SD card socket. Can you please take a look at these troubleshooting steps and see what you get?
    https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues
  • @Phaedrux I had a look into that page, here's the output of M122 following the startup message
    WiFi is disabled.
    M122
    === Storage ===
    And here is what happens when I try to access a file one the Card, in this case I just tried to flash the WiFi module as an example
    M997 S1
    Error: M997: File DuetWiFiServer.bin not found
    The board appears to be getting worse, the window of usefulness is shrinking, I suspect something is dying.
    Following the troubleshooting steps you linked, I have verified the SDCard socket is getting warm, but the WiFi module is very warm (48C), MCU just warm, this is after only a minute or two of power up.
    These tests were performed with USB connected only, no external power, and with 2 SDCards, one of which was supplied with the board.
    What next?
  • Moderator
    @zombiRon said in Aux(bad-csum): M408 S0 R13:
    What next?
    Please contact Oozenest and initiate a warranty replacement. You can direct them to this thread as authorization. Sorry for the inconvenience and thank you for your patience. And once again sorry for missing your post with the photos.
  • @Phaedrux Replacement board arrived today, straight forward swap out of the clone, once I jumped through the firmware v2 --> v3.0 --> v3.1.1 hoops, all working perfectly. Thanks for your assistance in resolving this.
