SOLVED Duet3HC not responding to Gcode ??
When I go in console from the Duet gui, the board doesnt respond to any Gcode I sent him, event the simple M119 (printer status..)
Is this a Duet 3 in standalone or connected to a pi?
Does the web control interface otherwise function as expected?
How do you send it? Do you press the enter key on your keyboard? Or do you use the send button? Do you copy and paste the g-code? I had similar problems when I copy and pasted the code and pressed enter. I think that is is a line feed problem.
connected to a pi4, using the web interface. everything else seem to work except I have no endstops (all n/a status). another problem.
@Chriss tried both, doest work. only gcode that work is m999
Have you updated the pi and duet firmware recently with sudo apt update sudo apt upgrade?
It would be helpful to know what firmware versions are currently installed.
@Phaedrux yes, all updated to the latest firmware (3.1.3)
@Phaedrux Ok so if their is a micro SD in the board it doesn't respond to Gcode except M999... I unplug and plug everything back, also drop the firmware to 3.0 (3.1 might had been the problem too) and removed the SD card.
You'll definitely want to stick with 3.1.1
