Fan stoped working
Sure, the Duex and Duet should have a common ground anyway, so wiring the fan between Vfan/Vin on the Duet and Fan- on the Duex should work. But determining what shorted out the other mosfets in the first place might be prudent. (ofc sometimes things just fail because reasons)
@bearer Cool... I will follow that way. I need that printer to continue the other build. I can debug the other problem in the future if I have some spare time.
I was a very good idea to by the Duex. That saved my ass a couple of times now.
Thanks for you help!
Cheers, Chriss
Use Vfan if you can, it gives you the benefit of the 1A fuse for the fans, or add your own fuse.
@bearer
This is, indeed, a very good idea.
