Trying to figure out what is giving the Bad Command error
I keep getting a Bad Command error when I start a print sliced in Cura, I don't get the same when I slice with Prusa.
Here is the first part of my G-code, hopefully someone can point out the problemThanks!
;FLAVOR:RepRap
;TIME:12738
;Filament used: 12.0943m
;Layer height: 0.2
;MINX:56.5
;MINY:56.5
;MINZ:0.2
;MAXX:178.5
;MAXY:178.5
;MAXZ:100
;POSTPROCESSED
;LINEARADVANCEPROCESSED
;Generated with Cura_SteamEngine 4.6.1
T0
M83 ;absolute extrusion mode
M201 X500.00 Y500.00 Z140.00 E5000.00 ;Setup machine max acceleration
M203 X9000.00 Y9000.00 Z6000.00 E6000.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset FlowrateG28 ;Home
M140 S60 ; start preheating the bed
M104 S205 T0 ; start preheating hotend
G28 ; home
G32M190 S60 ; heat to Cura Bed setting
M109 S205 T0 ; heat to Cura Hotend
​G32 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
M83 ;relative extrusion mode
G1 F2700 E-6
;LAYER_COUNT:500
M572 S0.000000 D0 ;added by LinearAdvanceSettingPlugin -
Does it mention what the bad command is?
@Dragon said in Trying to figure out what is giving the Bad Command error:
That should be G92
M201 X500.00 Y500.00 Z140.00 E5000.00 ;Setup machine max acceleration M203 X9000.00 Y9000.00 Z6000.00 E6000.00 ;Setup machine max feedrate M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
You should remove those commands from the Cura start gcode. They will override your config.g settings.
Also make sure you have cura set to reprap flavor gcode.
No, that's the problem just comes up as bad command.
I will look over what you posted, I had to remove the G92 to stop it pulling all the filament out after print and it is set for RepRap.Cheers.
You'll need to set Cura to use relative extrusion.
It is
Still had to run a script to make sure it did.Cheers.
Is it though?
If you go to the actual gcode console view does it tell you more about what bad command it is?
It's no longer backing the filament out after every print, but I am still trying to tune it have not started printing with it since installing the Duet WiFi.
Cheers.
No still just says bad command.
@Phaedrux said in Trying to figure out what is giving the Bad Command error:
Is it though?
That is the script entering the code but not changing the text.
open the file in an editor that shows you whitespace and non-printable characters?
I just tried that in Notepad++ but not sure if I got it right, that is the code copied from Notepad++ pasted at the start of the thread.
Thanks and Cheers.
@Dragon
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel accelerationThe wiki for M204 in RRF does not have an "R" parameter. https://duet3d.dozuki.com/Wiki/Gcode#Section_M204_Set_printing_and_travel_accelerations
Thanks, I have already taken those 4 lines out but still get the error.
Cheers.
i thought it printed the line that had the bad command, maybe just to usb?
anyways, i see a line with just whitespace below M109, so thats what made me think it may print the problem, its just not something we can see?
I will try removing that Thanks!
Cheers.
Ugh, that didn't get rid of it. LOL
What firmware version are you using? Most firmware versions usually report what the bad command was.
Can you post your homeall.g as well? Perhaps your bad command is in there.
