    Not Delta
    • brian444undefined
      brian444
      The web console thinks my printer is a delta, its actually a Cartesian that was working fine until i did the duet wifi upgrade. I dont know if this matters. None of the axis will respond to move commands from paneldue. The console reports "attempt to move the head of a delta printer before homing the towers". If i "home all" from the web control, the x and y axis lock up until i power down. Any help would be appreciated.
      • elmoretundefined
        elmoret
        You need to set up the config.g file for your printer. There are instructions on the wiki.
        https://www.duet3d.com/wiki
