Unsolved rotate/skew/resize coordinate system
While back I was using some small PCB milling machine made specifically for milling PCB's with closed firmware and front app but I was told, at the time, that what I was doing there is normally possible with most professional CNC controllers and even with popular mach3 or open source linuxCNC and that even GRBL supports this. I tried to figure out how to do it going through linuxCNC documentation but I fail short and since the idea is to run the machine with duet anyhow here comes the ...
I have a G-Code that goes something like
; some startup code, setting up stuff, turning on spindle etc etc G0X0Y0Z0 G1Z-0.5 G1X10 G1Y10 G1X0 G1Y0 G1Z-1 G1X10 G1Y10 G1X0 G1Y0 ; continue in the same way
so pretty clear that snippet will mill a 10x10mm square 1mm deep, and if I set the origin properly at 0,0,0 and I square the stock on the mill bed it will do what's required, but, often stock can't be squared to the bed so instead of squaring the stock to the bed and setting 0,0,0 I want to set 2 points, one is 0,0,0 and other is 10,0,0 or 10,10,0, or 20,10,0 or any "x,y,0" that i "know the value is". For example I move the print head to a point and set that to be 0,0 (this is easy), now I move the print head to 99.498,10 and set that point to be 100,0 so the firmware now rotate the working coordinates by 5.74 degrees counter clockwise
another thing is scew/resize, for e.g. I'm drilling pcb holes, pcb is etched for e.g., I have 3 (or more) feducials that I know coordinates of, I position my head over those feducials and enter their coords and the firmware do a rotate/resize of the coord system to match so when I then let the drill file go all holes ends up where they are supposed to.
Any idea if any of these can be done with RRF and if yes how
e.g. https://youtu.be/a_p38zktIZI
but with RRF -
@arhi said in rotate/skew/resize coordinate system:
not without G68/G69 implemented in RRF i think
https://en.wikipedia.org/wiki/G-code#G68
(edit: or external processing)
@arhi Probably not but is axis skew compensation any good for you ? https://duet3d.dozuki.com/Wiki/Gcode#Section_M556_Axis_skew_compensation
@deckingman said in rotate/skew/resize coordinate system:
it would not be linear after so probaly not.
@bearer said in rotate/skew/resize coordinate system:
Maybe. But if you look at what @arhi said, he wants to move to 99.498 and set that as being 100. So using M556, the length (S) would be 100 and the deviation would be 0.512. If he set that as the deviation for both X and Y, would that not effectively rotate the required amount? i.e. M556 S100 X-0.512 Y-0.512 Z0.
depends if thats applied to work place co-ordinates or not.
Ideally, you probe 2 points on the stock material in X and 2 points in Y. The firmware would then know where the origin is and skew the work piece accordingly. -
there is only one value for the xy plane, and one for yz, and one for zx as I'm reading it; so it will not be linear aftervif the machine is already trammed.
The X, Y and Z figures are the number of millimeters of the short side of the triangle that represents how out of true a pair of axes is. The X figure is the error between X and Y, the Y figure is the error between Y and Z, and the Z figure is the error between X and Z. Positive values indicate that the angle between the axis pair is obtuse, negative acute.
@bearer You are probably right but I can't really be bothered to think about it. I go back an awfully long time to the Duet 06 boards as used on the RepRap Pro Mendel. It used to be called "Orthogonal Axis Compensation" and was used to correct printers that were built from threaded rods and therefore the axes did not necessarily move at right angles to each other. That is what M556 was designed to compensate for.
correct; so if the machine does move at right angles and you adjust it, it will not rotate, but change the angle to be obtuse or acute instead - causing non-linearity.
I can't really be ars*d to think about it, but if you have a square and apply an orthagonal offset to X and the same offset to Y, don't you end up with the same square but rotated? How is it non-linear?
and we have only 53-59 ..
@arhi Is there any way that you could model the object as if it was going to be printed, then use a slicer to rotate it on the build plate and generate the required move co-ordinates?
great, skew is one of the things I want to compensate too. on large boards it happens that film stretches unevenly, especially if you make a board yourself and print on fscking samsung printer that will stretch the paus in length ... so hitting feducials with skew compensation should work .. need to check how it works with examples. I know TT printers use something like that (not trough g-code) to compensate for messed up mechanics
because if you do
thenX-0.512
causes the right angle at he XY plane to become slightly acute, andY-0.512
causes the same to happen to the YZ plane, the Y command doesn't change in relation to X, only Z. -
For any specific situation, everything is possible given time and energy. ATTM I'm thinking theoretically as the "big" mill I have (it's tiny compared to mills out there but it's much bigger than my MF70 conversion ) is ATTM out of operation due to linuxCNC computer that was driving it (via MESA card over ethernet) is dead. So now I have options
- [0] ignore it (most probably what's going to happen as I'm pressed with time, but I can "think" about solution in free time)
- [1] rebuild another PC for linuxCNC and reconfigure everything from scratch
- [2] make a small GRBL on STM32F103 (there's a port, ppl say it works nice)
- [3] make a quick smoothieboard compatible board and run smoothie in GRBL mode (as I do for my MF70 conversion but with real smoothieboard), it's easy as I already have big external drivers and power and everything else needed for that CNC
- [4] get duet3 and dump these ugly drivers I have as duet3 can supply required 4A for these motors
1 is something I'm trying to avoid as I don't have room for that PC and monitor and ..
2,3 are cheap and I already have everything I need to make it work but I'm trying to unify as much as I can and since I started migrating stuff to duet..
4 is expensive but makes sense in the long runNow this "rotation" and "resize" I have no clue if this can be done with GRBL/Smoothieware, but would be a good incentive to move to Duet3
So, back to the question, I have e.g. a g-code made for a PCB drilling, there's zero chance I can position that PCB ideally square on the bed so I need to be able to at least rotate but in most cases also to resize coordinate system. Yes I can manually measure, calculate and write a small piece of code to redo the coordinates in the g-code, but that's not practical. I can also do an octoprint plugin to do that on the fly, and if I go smoothieware/grbl way in case they don't support rotation I'll do just that, but no point of running octoprint + plugins with RRF, not a big point of spending the $$$ for duet then
@arhi or run RRF on an LPC board (e.g. SKR 1.4 or MKS SGen L) with your external drivers
i used to have a camera to align to one mounting hole drill, it deep enough to put a dowel pin in it, and align the other corner pivoting one the pin before clamping it down for good. If you can eyeball it without the cam then maybe that'll work?
btw linuxCNC for e.g. don't have G68 but has G10
http://www.linuxcnc.org/docs/2.6/html/gcode/gcode.html#sec:G10-L2_
that allow rotating one of the existing coordinate systems around Z axes
I still have camera (want to replace it btw) and it works ok when I want to mill the pcb, I do not move the pcb from the bed and all cool, but if I etch the pcb and wanna drill holes and cut slots it's PITA .. can be done but really PITA ... I would like to have it done "properly" with feducials, and with linuxCNC for e.g. G10 L2 will get the job done for rotations. The scaling is not that important but is a nice to have
