    Stuck with calibrating delta
    • dvdrielundefined
      dvdriel
      Hi all,
      Sorry for yet another delta calibration topic, but I can't figure it out with documentation and previous topics alone. I am replacing a Rumba board in a Tripodmaker to a Duet 2 WiFi. Everything worked out so far, but I am stuck on calibrating the machine.
      I measured the delta's geometry as accurately as possible:
      L: 335mm
      R: 185mm
      I checked these measurements several times and they are correct. For some reason, the vector plate moves very clearly in an arc. Did I configure the delta parameters wrong?
      For L I measured from bearing center to bearing center of the pushrods.
      For R I measured the horizontal distance between the bearing centers of the pushrods
      The second problem is that I have a bed that is adjustable with 3 screws. I tried to get it as flat as possible, but it is very hard to do manually. I thought the delta auto-calibration could do the rest, but it doesn't seem to work for me.
      I generated as many probing points as possible with the RRF config tool (see bed.g). I chose mode S8 since I am pretty sure my bed is tilted.
      When I run G32 the auto calib executes fine, but its adjustments seem very strange to me.
      Calibration results:
      Calibrated 8 factors using 19 points, (mean, deviation) before (1.042, 2.219) after (-0.297, 0.390)
      Adjustments after first auto calib run:
      Diagonals 355.000:355.000:355.000, delta radius 161.276, homed height 346.308, bed radius 115.0, X -1.892°, Y -5.364°, Z 0.000°
      I assume that the auto-calibration can't do much when the geometry parameters are this much off to start with? How can I fix this?
      My last question is about the calibration itself. Is it correct that the G32 calibration is for the correction of inaccuracies in the build of the printer and the measurements made by me? And that the mesh bed leveling is purely for correcting holes and dents in the build plate, so not for correcting bed tilt?
      Many thanks in advance for the people that could help me with getting my delta calibrated.
      Printer: Tripodmaker (delta)
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      config.g:
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 30 2020 00:49:16 GMT+0200 (Midden-Europese zomertijd)
      M550 P"3DPrintert" ; set printer name
      M665 R185 L355 B115 H350 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      ;M552 S2 ; enable access point mode
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X133.33 Y133.33 Z133.33 E400.49 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E1400 I10 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-7 Y-24 Z2.05 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M106 P0 C"BOTTOM" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M106 P1 C"EXTRUDER" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M106 P2 C"BED" S1 H-1 ; set fan 2 name and value. Thermostatic control is turned off
      M563 S"Printhead 1" P0 D0 H1 F1; tool 0 uses extruder drive 0 and heater 1
      G10 P0 S0 R0 X0 Y0 ; set tool 0 temperatures and offsets
      M501
      bed.g:
      G30 P0 X0 Y83.06 H0 Z-99999
      G30 P1 X44.17 Y76.51 H0 Z-99999
      G30 P2 X85.87 Y49.58 H0 Z-99999
      G30 P3 X110 Y0 H0 Z-99999
      G30 P4 X95.26 Y-55 H0 Z-99999
      G30 P5 X55 Y-95.26 H0 Z-99999
      G30 P6 X0 Y-110 H0 Z-99999
      G30 P7 X-55 Y-95.26 H0 Z-99999
      G30 P8 X-95.09 Y-54.9 H0 Z-99999
      G30 P9 X-94.54 Y0 H0 Z-99999
      G30 P10 X-74.38 Y42.94 H0 Z-99999
      G30 P11 X-41.14 Y71.26 H0 Z-99999
      G30 P12 X0 Y33.23 H0 Z-99999
      G30 P13 X36.61 Y21.14 H0 Z-99999
      G30 P14 X47.63 Y-27.5 H0 Z-99999
      G30 P15 X0 Y-55 H0 Z-99999
      G30 P16 X-42.81 Y-24.72 H0 Z-99999
      G30 P17 X-30.05 Y17.35 H0 Z-99999
      G30 P18 X0 Y0 H0 Z-99999 S8
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Carloundefined
        Carlo @dvdriel
        @dvdriel
        Sorry what probe are you using ?
        Also try using S6 (6factor) instead of S8
        Did you follow this guide ?
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        • dvdrielundefined
          dvdriel
          I am using a NPN inductive switch. I went through the whole delta setup several times, but can't seem to get my machine calibrated properly.
          6 factor calibration did indeed work better, but I chose for 8 factor on purpose because of my type of bed. Next to that I still don't get why my vector plate moves so clearly in an arc before auto calibration. My measurements can't be that much off right?
          • Carloundefined
            Carlo @dvdriel
            @dvdriel
            I think whilst in the getting it set up and calibrated take out the 501 a and delete or rename the config override file now is not your friend as you are making changes that that file may be overriding and giving you false results use the 6 or if you are sure your radius is correct use 4 factor even
            Use a feller gauge to set your bed as best you can at a specific height like 0.1mm Move your effector around the bed adjusting the bed don’t home after calibrating as homing wipes the calibration.
            I’m sure other Delta users will get involved but I had a journey getting mine calibrated which turned out to be a faulty part so if your convinced in your process being solid don’t rule out a loose idler or bolt as most of the time as I’m sure the developers will agree it’s the most common cause.
            Are you heating the bed before calibration ? Ideally you are to 60c
            Is your sensor accurate ? No loose wires/crimp?
            Is it consistently giving the same deviation? With out changing any settings as to say if you calibrate 5 times does the deviation change?
            Hope this is of help
            C
