    Duet 3 - Adding a rotationnal axis
    • Pierrelitoundefined
      Pierrelito
      I am currently implementing a Duet 3 in my printer and I have a question regarding the Axis limitations of the Duet.
      Would it be possible to have a rotationnal axis (servo driven) RX RY or RZ (for orientation printing with non round nozzle or CNC router) in Reprap Firmware ?
      Thank you in advance
      • A Former User?
        A Former User
        when you say servo you mean which servo?
          Pierrelito
          Any servo Rc like or even stepper that would be able to be given a new axis.
          The goal would be to replicate this kind of system: c93a44e4-7a2b-4c9d-95c5-11403179135d-image.png (shorturl.at/hEW48)
          • fmaundefined
            fma
            How do you plan to drive this axis? Do you need the firmware to automatically rotate it for you, according to some XY moves? Or do you generate its position yourself, by post-processing G-Code from a script, for example?
            Frédéric
              Pierrelito
              The command would come directly from the gcode
              • fmaundefined
                fma
                Is the G-Code something like G1 A32.5?
                You can post-process the script and change this command to M280 P0 S32.5...
                Frédéric
