GCode file causes partial(?) reset
And a other this time with some error from DCS before
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DGM-9T66A-G63SJ-6J1D6-3SD6R-9U0BA Used output buffers: 1 of 40 (13 max) === RTOS === Static ram: 154604 Dynamic ram: 162672 of which 188 recycled Exception stack ram used: 520 Never used ram: 75232 Tasks: NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3424) CanSender(suspended,1428) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2868) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:28:09 ago, cause: power up Last software reset at 2020-07-05 15:48, reason: User, spinning module LinuxInterface, available RAM 75268 bytes (slot 3) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 36.7, current 37.0, max 37.1 Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0 Driver 0: standstill, reads 36602, writes 8 timeouts 0, SG min/max 0/595 Driver 1: standstill, reads 36601, writes 8 timeouts 0, SG min/max 0/1023 Driver 2: standstill, reads 36610, writes 0 timeouts 0, SG min/max not available Driver 3: standstill, reads 36601, writes 8 timeouts 0, SG min/max 0/101 Driver 4: standstill, reads 36602, writes 8 timeouts 0, SG min/max 0/993 Driver 5: standstill, reads 36602, writes 8 timeouts 0, SG min/max 0/1023 Date/time: 2020-07-10 19:50:02 Slowest loop: 5.16ms; fastest: 0.21ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 349, MaxWait: 256811ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.52ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 2575, longest wait 1ms for type 6013 === Linux interface === State: 0, failed transfers: 0 Last transfer: 19ms ago RX/TX seq numbers: 1318/52023 SPI underruns 0, overruns 0 Number of disconnects: 1 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 29.32 -
I updated the 3.2 build and now I cannot connect to the board cleanly anymore. DCS complains:
Jul 10 21:05:02 vcore-pro DuetControlServer[1692]: [fatal] Could not connect to Duet (Board is not available (no header)
It's getting late here -- I will probably need to reflash via BOSSA to 3.1.1 and then see how to continue.
Back to 3.1.1 once more tonight -- I'm getting comfortable with BOSSA (-:
A freshly booted machine again crashes when uploading and starting a print via DWC:
console entries:
7/10/2020, 9:27:42 PM Upload of 1515-T-connector-vcore-pro.gcode successful after 3s 7/10/2020, 9:27:44 PM M32 "0:/gcodes/1515-T-connector-vcore-pro.gcode" File 0:/gcodes/1515-T-connector-vcore-pro.gcode selected for printing 7/10/2020, 9:27:45 PM Connection interrupted, attempting to reconnect... DCS has been stopped 7/10/2020, 9:27:54 PM Connection established
I Immediately ran an M122:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DGM-9T66A-G63SJ-6J1D6-3SD6R-9U0BA Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 154604 Dynamic ram: 162880 of which 188 recycled Exception stack ram used: 520 Never used ram: 75024 Tasks: NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3396) CanSender(suspended,1444) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:09:44 ago, cause: power up Last software reset at 2020-07-05 15:48, reason: User, spinning module LinuxInterface, available RAM 75268 bytes (slot 3) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 26.7, current 35.6, max 35.9 Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0 Driver 0: standstill, reads 22793, writes 49 timeouts 0, SG min/max 0/1023 Driver 1: standstill, reads 22793, writes 49 timeouts 0, SG min/max 0/856 Driver 2: standstill, reads 22832, writes 11 timeouts 0, SG min/max 0/0 Driver 3: standstill, reads 22824, writes 19 timeouts 0, SG min/max 0/154 Driver 4: standstill, reads 22825, writes 19 timeouts 0, SG min/max 0/210 Driver 5: standstill, reads 22825, writes 19 timeouts 0, SG min/max 0/97 Date/time: 2020-07-10 21:27:59 Slowest loop: 4.65ms; fastest: 0.14ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 372, MaxWait: 42423ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 107, completed moves: 107, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1.02ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 2343, longest wait 2ms for type 6011 === Linux interface === State: 0, failed transfers: 0 Last transfer: 16ms ago RX/TX seq numbers: 181/17363 SPI underruns 0, overruns 0 Number of disconnects: 1 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 Daemon: Finishing macro daemon.g, started by system > Next stack level Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 20.83
This is the gcode file in question:
It's notable that the printer is still homed, so it wasn't a full reset.
(DWC 3.1.1, RRF 3.1.1)
Over the weekend I did a couple slices with Superslicer (PrusaSlicer fork) which did not cause the reset. I'll try to come up with minimal gcode with as little differences as possible to see if I can isolate what causes this. It will take some time though since I'll be traveling for work this week.
