New duet 2 WiFi install issues
Got connect via usb to setup wireless and then was able to connect to it wirelessly. Started the wiring part and now I’m unable to get to it and the red diag light is on. Can’t get to it via usb or wireless now. Thanks in advance for any guidance.
please see https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
espescially remove sd card and the
recovery procedure #3"Fall-back procedure #3"
Thank you, that was able to resolve that. Im in now but my "tool 0 " heater 1 is throwing a fault now. When i click on it i get "Error: Temperature reading fault on heater 1: sensor open circuit" Was hoping for some help on that as well. thank you.
Here are some logs.
2020-02-19 15:05:06 Event logging started
2020-02-19 15:05:06 HTTP client 192.168.1.135 disconnected
2020-02-19 15:05:09 HTTP client 192.168.1.135 login succeeded
2020-02-19 15:05:25 Event logging stopped
2020-07-05 21:43:25 Event logging started
2020-07-05 21:43:25 Error: Heater 2 not found
2020-07-05 21:43:25 Error: Tool creation: bad drive number
2020-07-05 21:43:25 Error: Fan number 2 not found
2020-07-05 21:44:25 Error: Attempt to set/report offsets and temperatures for non-existent tool: 2
2020-07-05 21:44:41 Error: Fan number 2 not found
2020-07-05 21:44:41 Error: Attempt to set/report offsets and temperatures for non-existent tool: 2
2020-07-05 21:45:13 HTTP client 10.1.2.173 login succeeded
2020-07-05 21:47:15 Error: Heater 0 fault: temperature rising much more slowly than the expected 1.6°C/sec
2020-07-05 21:48:49 Error: G0/G1: insufficient axes homed
2020-07-05 21:49:51 Error: M140: Can't activate heater 0 while in fault state
2020-07-05 21:52:46 HTTP client 10.1.2.173 login succeeded
Perhaps edit your title with your new issue, or start a new thread. Mark this one solved.
Either way, post the results of an M122, and your config.g and homeall.g
If the heater is open circuit, check the wiring.
For the bed heating too slowly, PID tune it.
For the G0G1 error, it means you're trying to move an axis before it's homed. Usually lifting the Z axis before homing X and Y. Add H2 to the z lift.
@Phaedrux said in New duet 2 WiFi install issues:
Thank you! kinda new to this, so on the top i type in M122 and hit send right? where or what are the results?
thank you again.
Config.g:
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:26 GMT-0500 (Central Daylight Time); General preferences
M550 P"Schaal3DPrinter" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X225 Y225 Z300 S0 ; set axis maxima; Endstops
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
homeall.g
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:27 GMT-0500 (Central Daylight Time)
G91 ; relative positioning
G1 H1 X-230 Y-230 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-230 Y-230 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z305 F360 ; move Z up stopping at the endstop
G90 ; absolute positioning
G92 Z300 ; set Z position to axis maximum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
M122:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N8PS4-7J1FJ-3SJ6S-189BQ
Used output buffers: 3 of 24 (21 max)
Static ram: 27980
Dynamic ram: 93732 of which 44 recycled
Exception stack ram used: 472
Never used ram: 8844
Tasks: NETWORK(ready,364) HEAT(blocked,768) MAIN(running,1880) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:49:56 ago, cause: power up
Last software reset at 2020-07-05 21:24, reason: User, spinning module GCodes, available RAM 9912 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 26.6, current 28.8, max 29.6
Supply voltage: min 23.8, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/87
Driver 1: standstill, SG min/max 61/185
Date/time: 2020-07-05 22:42:51
Slowest loop: 16.89ms; fastest: 0.13ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.5ms, write time 5.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 1465810ms
=== MainDDARing ===
Scheduled moves: 15, completed moves: 15, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 79.80ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address bc:dd:c2:2d:67:97
WiFi Vcc 3.39, reset reason Unknown
WiFi flash size 4194304, free heap 21720
WiFi IP address 10.1.2.149
WiFi signal strength -56dBm, reconnections 0, sleep mode modem
- WiFi -
