BLTouch + additional servo
I´m trying to set an servo for my tool changer (something like Prusa MMU) but the config for servo isn´t that easy for me.
My Setup:
Duet Wifi
Duex5
BLTouch
miniServo- BLTouch is running for Z-probe and connected to Heater 5 of duex5
- the servo I´d like to control is connected to Heater 4 of duex5
The BLTouch is running in z probe w/o any issues but the other servo doesn´t move if I want
M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch (default from Config Tool) M950 S1 C"duex.pwm4" ; additional servo
I guess my thinking isn´t correct. Please help me to understand how it works
How are you trying to command movement of the additional servo?
like this over command line:
M280 P1 S150
using that servo
Savox SC-0254MG
@Computiger said in BLTouch + additional servo:
Do you really mean Heater 4, or do you mean PWM4 ?
I´ve just tried two other servo´s, these ones run fine like accepted.
They are much cheaper than the 1st one. I have to check the wire.Thanks
