    new official bltouch 2020
    bl touch
    • npm1undefined
      npm1
      Looking to purchase the new bltouch, the question I have is whether I need to solder any thing to bring the voltage down or scrape anything of.
      The website mentions that the bltouch is switchable between 5v/3.3v in the software.
      Please correct me if I'm wrong.
      Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
        No you don't need to make any alterations to the BLTouch. If you are using it with RepRapFirmware 3 on a Duet WiFi/Ethernet/Maestro board then you need to enable the pullup resistor on the input port in the M558 command in config.g.
        • npm1undefined
          npm1
          so i could just use the bltouch out of the box be it a 5v bed levelling sensor, would this also work for the 5v inductive probes.
          I currently have duet wifi with the removable fuse. I tke it your referring to the bltouch v3
          Thnks you in advance
            Yes out of the box it should work fine. Though I'm not sure if anyone has reported on using the 2020 version yet, so do let us know if you have any issues, but if it's anything like the past v2 and v3 versions it should work without issue with no alteration.
