SOLVED Duex5 not showing in diagnostics
Hi there,
The 2x steppers (extruders) patched into my duex5 are not responding at all. I also have a BL touch + 1 extra servo plugged into the duex which are working perfectly. I have read that a M115 diagnostic should be showing the duex5 but is not. On reading other threads I have followed the advise given and checked that the wiring is all snug and correct. I have also checked the ribbon cable and all appears well with this. The steppers were working previously even though the duex5 was not showing up on the diagnostics so I though if it wasn't broke then don't try to fix it.
Diagnostics as follows:3:12:48 PMM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet Ethernet 1.02 or later
Board ID: 08DGM-917NK-F2MSW-6JKFA-3SD6R-1H5DF
Used output buffers: 1 of 24 (14 max)
Static ram: 28180
Dynamic ram: 93456 of which 20 recycled
Exception stack ram used: 272
Never used ram: 9144
Tasks: NETWORK(ready,836) HEAT(blocked,1224) MAIN(running,1912) IDLE(ready,80)
Owned mutexes:
Last reset 00:45:55 ago, cause: power up
Last software reset at 2106-02-07 06:28, reason: deliberate Unknown, spinning module unknown, available RAM 4294967295 bytes (slot 1)
Software reset code 0xffff HFSR 0xffffffff CFSR 0xffffffff ICSR 0xffffffff BFAR 0xffffffff SP 0xffffffff Task ����
Error status: 0
MCU temperature: min 33.5, current 34.7, max 35.2
Supply voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-07-08 15:12:46
Slowest loop: 7.26ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 5.36ms; fastest: 0.06ms
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplexConfig G as follows:
; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 12:21:41 GMT+1000 (Australian Eastern Standard Time); General preferences
M550 P"Vandal" ; set printer name; Network
M552 S1 P0.0.0.0 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S1 ; physical drive 1 goes forwards X
M569 P2 S0 ; physical drive 2 goes backwards Y
M569 P0 S1 ; physical drive 0 goes forwards Z1
M569 P3 S1 ; physical drive 3 goes forwards Z2
M569 P4 S1 ; physical drive 4 goes forwards Z3
M569 P5 S1 ; physical drive 5 goes forwards E0
M569 P6 S1 ; physical drive 6 goes forwards E1M584 X1 Y2 Z0:3:4 E5:6 ; set drive mapping
M350 X16 Y16 Z16:16:16 E16:16 I1 ; configure microstepping with interpolation
M92 X80.00 Y40.00 Z1216.00:1216.00:1216.00 E420.00:420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00:12.00:12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00:180.00:180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00:20.00:20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1600 Y1600 Z1600:1600:1600 E1600:1600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X600 Y430 Z700 S0 ; set axis maxima
M671 X300:4:595 Y-150:540:540 S20 ; leadscrews at rear left, front middle and rear right; Endstops
M574 X1 S1 P"nil" ; Make x endstop available
M574 Y1 S1 P"nil" ; Make y endstop available
M574 Z1 S1 P"nil" ; Make z endstop available
M574 X1 S1 P"!ystop" ; configure active-low endstop for low end on X via pin ystop
M574 Y1 S1 P"!zstop" ; configure active-low endstop for low end on Y via pin zstop; Z-Probe
M558 P9 C"^zprobe.in" H10 F120 T5000 ; set Z probe type to unmodulated and the dive height + speeds
M950 S0 C"duex.pwm4" ; configure servo pin0 for 3D Touch
G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X50:600 Y20:360 S80 ; define mesh grid; Tool changing Servo
M950 S3 C"duex.pwm2" ; configure servo pin3 for rocker; Heaters
M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M143 H2 S280 ; set temperature limit for heater 2 to 280C
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 S"Hotend 0" D0 H1 F0 ; define tool 0
M563 P1 S"Hotend 1" D1 H2 F0 ; define tool 1
G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
And here is a photo of the wiring:
I look forward to your reply.
Damien
Sorry, this is the photo I should have attached
WOW!! Not one single comment. Is this not being seen or has it been put in the 'too hard' basket?
If anyone see's this thread I would like to add that I could only get the servos to work on the duex by dropping the "!" in M950 S0 C"duex.pwm4" for the bl touch and M950 S3 C"duex.pwm2" for the tool changing servo. ANY help would be much appreciated!
I'm sorry. Most likely your DueX is faulty, although there is a chance it could be the ribbon cable instead (and a very small chance that it could be the Duet). Please contact your supplier to have the DueX5 and ribbon cable replaced under warranty.
@genseric said in Duex5 not showing in diagnostics:
That's correct, you do not need to use ! in the pin name when connecting servos to the duex.pwm# pins, or when connecting them to exp.heater# pins on the expansion connector.
We try and reply to every post as quickly as possible. Please allow at least 24 hours for a reply and keep in mind that we're all spread across many time zones.
@Phaedrux My apologies for sounding impatient. You guys are always so professional and patient. I watched replies happen all around my post and thought that maybe it wasn't worth a look in from you guys (mistakenly so).
I have a new duex 5 and is is being recognised by the diagnostics. Success.
I am having trouble getting my extruder steppers to work but I will start a new topic as this one is solved!
Thanks for your patience. Glad the new board is working properly.
