5V Fans on 24V with PWM
Hello everybody,
Goal: Use of 5V fan and PWM control at the hotend. Since I want to switch everything on and off via PS-ON, I take the detour from the 24V power supply via the step-down controller.
I ask an electronics technician to take a look at the attached circuit diagram to see if it works that way.
Thanks in advance for help
it looks like it should work, but why not use the jumper to select 5v to the fan headers?
The Duet 2 WiFi and Ethernet boards have three controlled fan connectors FAN0, FAN1 and FAN2 plus two always-on fan connectors. A jumper (V_FAN) allows you to select whether all fans are powered from the VIN supply or from the Duet's 5V supply.
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
Thank you for your quick reply!
Because I still use a 24v fan (120x120mm) for board cooling (allways-on) and FAN2 for 24V-LED's pwm-controlled.
... and in addition, all consumers should always be able to be switched off using PS-ON
Why you don't use the 5V from the PSU ?
The DCDC converter are not usefull
Right, well, it would work as is.
But you might get away with just 1 step down converter,
or even use the external 5v supplydepending on the current draw/available current.Also adding an fuse at any point is also a good idea.
@bearer said in 5V Fans on 24V with PWM:
But you might get away with just 1 step down converter, or even use the external 5v supply depending on the current draw/available current.
OK, 1 stepdown is enough AND adding a fuse
Edit: 1 Fan needs 0,15A, so 1 stepdown is enought (1A without heatsink possible)
edited version:
so ok?
with the other requirements then its purrrrrfect!
@bearer
