    Node mcu with duet 0.8.5
    1
    420
    • redundefined
      red
      i have a duet 0.8.5 and a spare node mcu …so i thought ill put the two together and get some wifi going 🙂 i know this can be done because since the duet wifi runs on esp8266mod .
      http://forums.reprap.org/read.php?2,582444,723411,page=3
      https://www.thingiverse.com/thing:1397966
      now that post is from 2015
      the code would have evolved
      so im planning to flash the node with DuetWebControl firmware then run connections into the board
      im pretty sure it wont work
      cuz
      Important! Each version of DuetWebControl usually only works correctly with the version of RepRapFirmware that was current at the time of its release. Therefore, if you need to update both RepRapFirmware and DuetWebControl, update RepRapFirmware first.
      so what are my options
      anyone know of a firmware compatible with 0.8.5 ..?
