duet 3 expansion 3HC burnout-
  • hi,
    im using duet 3 main board (6hc) + duet 3 expansion board for a while,
    the setup is a Cartesian printer with multiple tools.
    firmware version: RC-12 _3.1.1.1
    web cotrol: version 3.1.1
    here is my config file:
    G90                                             ; send absolute coordinates...
    M83                                             ; ...but relative extruder moves
    M550 P"HH2"                              ; set printer name
    M552 p192.168.200.9 S1                          ; enable network
    M586 P0 S1                                      ; enable HTTP
    M586 P1 S0                                      ; disable FTP
    M586 P2 S0                                      ; disable Telnet
    M569 P0 S0                       ; physical drive 0 goes forwards
    M569 P1 S1                       ; physical drive 1 goes forwards
    M569 P2 S0                       ; physical drive 2 goes forwards
    M569 P3 S1                       ; physical drive 3 goes forwards
    M569 P4 S0                       ; physical drive 4 goes forwards
    M569 P5 S0                       ; physical drive 5 goes forwards
    M569 P1.0 S1 R1 D2                     ; Drive E0
    M569 P1.1 S1 R1 D2       ; E1 printhead
    M569 P1.2 S1 R1 D2                   ; E2 printhead
    M569 P2.0 S1 R1 D3                   ; E2 printhead
    M569 P2.1 S1 R1 D3                   ; E2 printhead
    M584 X0 U1 Y2:3 Z4:5 E1.0:1.1:1.2:2.0:2.1:2.2                              ; set drive mapping
    M350 X16 U16 Y16:16 Z16:16 E4:4:4:4:4:4 I1           ; Configure microstepping with interpolation ;
    M92 X100 U100 Y80.00 Z462.5 E80:80:75:75:80:100 ; set steps per mm
    M566 X700 Y1500 Z250 U700 E800:800:800:800:800:800 ; set maximum instantaneous speed changes (mm/min)
    M203 X15000 U15000 Y15000 Z2000 E10000:10000:20000:15000:15000:15000 ; set maximum speeds (mm/min)
    M201 X3000 U3000 Y2000 Z300 E500:500:500:500:2000:500 ; set accelerations (mm/s^2)
    M906 X2000 U2000 Y1500 I10     ; set motor currents (mA) and motor idle factor in per cent
    M906 E2100:2100:1400:1400:4000:1400 I10
    M906 Z2100 I50     ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                         ; Set idle timeout
    M208 X0 U0 Y0 Z0 S1                                ; set axis minima
    M208 X550 U550 Y450 Z2000 S0                          ; set axis maxima
    M564 S1 H0 ; Allow axis move without home and outside boundries
    M206 X-50 Y0 U-50 ;offset axes
    M574 X1 S1 P"io0.in" ; configure for low end, active-low endstop on X via pin io1.in
    M574 Y1 S1 P"io1.in" ; configure for high end, active-low endstop on Y via pin io2.in
    M574 U1 S1 P"io2.in" ; configure for high end, active-low endstop on Y via pin io2.in
    M140 H-1                                        ; disable heated bed (overrides default heater mapping)
    M563 P0 X0 D4:5 S"F0" ;Define tool 0
    M567 P0 E0.5:1 ;MIXING RATIO tool 0
    M563 P1 X0 D4:5 S"F1"   ;Define tool 1
    M567 P1 E1:1.7 ;MIXING RATIO tool 1
    M563 P2 X0 D3 S"F2" ;Define tool
    M563 P3 D1:4 S"F3" ;Define tool
    M567 P3 E0.5:1.5 ;MIXING RATIO tool 1
    M563 P4 X0 D5 S"F4" ;Define tool
    G10 P0 X-138.0 Y100.0 Z0.0                               ;Set tool 0 axis offsets
    G10 P1 X-144.0 Y0.0 Z0.0                               ;Set tool 1 axis offsets
    G10 P2 X0.0 Y0.0 Z0.0                            ;Set tool 1 axis offsets
    i was printing in usually way it work just fine.
    than, i heard a bang sound and when i went to check i discovered that my expansion board has black mark on its CPU chip.
    i wasnt operating it at the moment but later when i check it it didnt was functional, the fuse light gone only the blue one was on.
    i dont know what was the cause the bang i had to replace the board after.
    anyone experienced the same?
    thank you beforehaed.
    Hi @moo16 It sounds like there was a short between your VIN power and another signal on the expansion board. Please carefully check your wiring ans that sort of short may only occur when it is bent in a specific way.
  • thank you
    checked.
    everything look good.
    i replaced the board with new one and works good.
  • @moo16 said in duet 3 expansion 3HC burnout-:
    hi,
    should i send the board back to the supplier?
  • Moderator
    Where and when was it purchased? Can you post photo of the damage?
