    How to disable the max hot end temperature/power ?
    My Duet controlled machine
    330
    • jrocklandundefined
      jrockland
      Please let me know if there is a way to do it, Ill sign a waiver if required.
      I am running a 500c and working on a 700c setup for aluminium.
      My current hot end can easily reach and keep the temperature but for the moment I have to run external controller..
        You can set the max with M143
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M143_Maximum_heater_temperature
        Or am I missing something?
        jrocklandundefined 2 Replies Last reply Reply Quote 0
          jrockland
          *** Also please don't reply directly here, send me a pm as I don't want to be responsible if someone else do it on a normal 3d printer and burn down his house..
            jrockland @Phaedrux
            @Phaedrux you can but my hot end are too powerful for the firmware base setting.
              jrockland @Phaedrux
              @Phaedrux to give you an exact number, in the m307 setting, if I run my heater at 50% I am at a1594 and the maximum allowed is 1499. havent tested at 100% yet.
              A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
              • A Former User?
                A Former User @jrockland
                @jrockland said in How to disable the max hot end temperature/power ?:
                The duty cycle won't affect that much at all - it is the max predicted temperature if the fimrware fails and the heater goes always on.
                Athough there is likely some variance between runs so you might get under 1499 after a few tries.
                The other option is to edit the firmware to raise the limit (or drop the voltage/add a series resistnace just for the calibration)
                jrocklandundefined 1 Reply Last reply Reply Quote 0
                  jrockland @A Former User
                  @bearer well yes it is what I am looking for, I need the firmware 'error alarms' to be disabled or modified so it fit my hotends..
                    What are the hotends?!
                      dc42 administrators @jrockland
                      What M143 setting are you using?
