    M401 don't deploy the Bltouch
    Firmware installation
    • Émileundefined
      Émile
      I have a Duet maestro, the firmware version is 2.0
      I did the wiring and everything goes well. Motors are moving, limits switch are good, fans are running, bed and extruder are heating. Even the Bltouch is working... but only when I power-up my printer. My probe is deploying and retracting twice at the start but when I send the M401 command the Bltouch is not deploying. The G30 does not work either, it lower the z but the probe is not deployed.
      I wired my Bltouch in the probe connector :
      2dc19049-2a7a-4ee5-8f29-75a1d03c6011-image.png .https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/BJKPq1sdZcJNUmP4.standard
      My config.g :
      ; Configuration file for Duet Maestro (firmware version 2.00)
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Jul 16 2020 22:15:33 GMT-0400 (EDT)
      M550 P"Cr10-P0" ; set printer name
      M551 P"cr10" ; set password
      M552 P192.168.2.55 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.2.1 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E97.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X250 Y280 Z310 S0 ; set axis maxima
      M574 X1 Y1 S1 ; set active high endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X40 Y40 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:210 Y15:240 S15 ; define mesh grid
      M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
      M106 P0 S1 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T80 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T80 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M911 S22 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      My bed.g :
      ; bed.g
      G29 ; probe the bed and enable compensation
      My deployprobe.g
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P64 S10 I1 ; deploy BLTouch
      My retractprobe.g
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P64 S90 I1 ; retract BLTouch
      thanks for any help
      JoergS5undefined 1 Reply Last reply Reply Quote 0
        Remove the I1 parameters from the M280 commands in deployprobe.g and retractprobe.g files.
        Émileundefined 1 Reply Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5 @Émile
          @Émile said in M401 don't deploy the Bltouch:
          If it's still not working after dc42's change, please set P to 25 for
          because in most cases P25 is used for BLtouch, so please set it to
          G31 P25 X40 Y40 Z2.5
          • Émileundefined
            Émile @dc42
            Tanks a lot! It work!
            But now when I send G30 the Bltouch don't really trigger. It retract when touching the bed but the z axis don't stop. On the interface the Z-Probe stay 0.
            config.g :
            G31 P25 X40 Y40 Z2.5 ; set Z probe trigger value, offset and trigger height
            deployprobe.g :
            M280 P64 S10 ; deploy BLTouch
            retractprobe.g :
            M280 P64 S90 ; retract BLTouch
            homez.g :
            G91 ; relative positioning
            G1 S2 Z5 F6000 ; lift Z relative to current position
            G90 ; absolute positioning
            G1 X-25 Y-25 F6000 ; go to first probe point
            ;G91 ; relative positioning
            ;G1 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
              Phaedrux Moderator @Émile
              Double check the white wire for continuity.
              Also, if you're using firmware 2.0 you should really consider updating to at least 2.05.1.
