Autolevel sensor not working properly
  • undefined
    ander
    Hi there!
    i´m updating my prusa hephestos2 to duet and i´m trying to make the original autolevel sensor work but the duet keeps saying the sensor it is already activated.
    when turning on the duet already says P1000 altho it is at 100 mm height, when i aproximate a metalic thing to it it changes to 0 so it detects well.
    I am going crazy trying to change it to 0 when is high but i can´t do it.
    also the hitting sensors show 2000 degrees, i´m using the original ones of 95k
    config(3).g I´ll put my config file so anyone can help me please.
    this is my setup:
    Firmware Version: 2.03beta3 (2019-03-25b6)
    WiFi Server Version: 1.23
    Web Interface Version: 1.22.6
    • undefined
      ander
      i updated to firmrware 3.0 and the temp sensors read well but still having issues with the autolevel sensor working in the opposite way
      • undefined
        ander
        This is my last config file:config(4).g
        • undefined
          Please update to firmware 3.1.1 by uploading this file https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
          That should get you up to date with firmware and web interface.
          Then for your probe, what type of probe is it?
          1 out of 4
