Solved Possibly fried duet with an in spec power supply
@droftarts said in Possibly fried duet with an in spec power supply:
@Luckypriest or remove the ESP and test it with an Arduino?
oh yes! or an ftdi 3.3v usb ttl adapter could also be used, (maybe evnen prior to removal to see if the uart on the esp is ok - but depending on the fault it might work outside the circuit even if it doesn't work in the circuit)
Thanks guys, this is a lot for me to process. I'm going to try giving the wifi replacement a shot, and if that doesnt work might play around with CPU replacement, if only to see if I can. This is a lot for me to process, fairly new to actually messing with circuit boards.
if you remove the wifi and find it faulty, there is now the option to use a Raspberry Pi like the Duet3, so if you have one (not 1st gen and not zero) laying around that might be an option once support is fully tested and released.
(Low temperature bismuth* solder or a chipquik smd removal kit will make removal of chips with external pins a lot easier and reduce the risk of damage to the board. Some good flux also makes installing new chips a lot easier
*) 57Bi42Sn1Ag or 58Bi42Sn alloyes seem common even with no-name brands)
Thanks again. I have the new board updated, that went fine. Wired up power supply and tested voltage. Using a 360w power supply this time. Tested it. Wired for board but havent turned it on because.... I'm not nervous your nervous.
Anyone see any issues?
Bearer did me a solid and looked over it, recommended better terminal connection. POWERED ON! We in here bois.
@Luckypriest, did you try to replace the WiFi module? I think there is a good chance that will get the board working.
@dc42 I havent yet, got a replacement board and successfully got that powered on. Doing that replacement is going on the backburner for a bit while I finish this printer. I've gone ahead and marked this topic and closed.
