    Defining dual (independent) Z stepper driver in RRF Config Tool
    • Bluemaluundefined
      Bluemalu
      Taking advantage of my Duet3 MB 6HC to split my steppers (BigBox Dual). I'm assuming I define it as E3 and configure it as Z then add the magic code into the file later. Is this correct?
        Yes at the moment you will need to modify the config.g manually afterwards to include the additional driver for the Z axis.
        See here for examples: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
