BL touch Working on duet2wifi but not on duex5
Hello.
I am trying to use a BL touch on my 3D printer.
First of all, I connected my BL touch to pin 31(heater 7), 5V and ground on the Duet2wifi and worked perfectly.Now I have connected a Duex5 expansion board and reconnected a BL touch to PWM5 on the Duex5 board.
My RR Firmware is 2.05.
According to use a Duex5 board, I changed the parameters in config.g, deployprobe.g and retractprobe.g files as follows.M307 H7->H3 A-1 C-1 D-1
M280 P7->P3 I1->(erase) S10
M280 P7->P3 I1->(erase) S90When I turned the swich on the BL touch doesn't light up.
Are there anything else I need to modify?
Please help me.
I believe the H7 and P7 is correct for PWM5 on the Duex5 board.
@fcwilt Thank you for your post.
I have tried H7, P7,P7 but it didn't light up...
This means that the PWM port is not giving any power......
I am really confused...
@Hiroaki said in BL touch Working on duet2wifi but not on duex5:
I am really confused...I checked my setup and this is what I have:
M307 H7 A-1 C-1 D-1 ; step 1 - disable E6 heater to enable PWM5 - PWM signal still appears on E6 connector M558 P9 H2 F600 T12000 A5 S0.01 R0.2 ; step 2 - set probe configuration - part 1 G31 X0 Y24.5 Z1.475 P25 ; step 3 - set probe configuration - part 2 M280 P7 S160 ; clear BLTouch alarm (if any)
This post is deleted!
Good morning.
Thank you so much.
I have found that there was no jumper on the duex5 board which is to set 5V aux select.
No other jumper is on the Duex5 board now.
I hope it's ok...
