mesh bed leveling issue
ok i am trying to get the run mesh compensation my printer is 220 x 220 and i have it were it homes in the middle .
when i press the mesh compensation it starts in the middle of the bed and not the top left . what do i need to do to get it to move to the top left for mesh compensation ? no files on my sys for mesh .
; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Jul 23 2020 14:47:56 GMT+0300 (Arabian Standard Time); General preferences
M550 P"Anet A8" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X100.00 Y100.00 Z400.00 E409.00 ; set steps per mm
M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-13 Y-3 Z0 S1 ; set axis minima
M208 X200 Y170 Z240 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
;M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
M574 Z0 ; configure Z-probe endstop on Z; Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T2000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y-40 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X55:200 Y55:170 S60 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S130 ; set temperature limit for heater 0 to 130C
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
T0 ; select first tool_________________________________________________________________________________________________________________________; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-258 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
;G1 H1 Z-245 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
G1 X114 Y83 F4000 ; Move probe to middle of bed
G30
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
@morf33 said in mesh bed leveling issue:
M208 X200 Y170 Z240 S0 ; set axis maximaHi,
What do you mean by "homes in the middle"?
Thanks.
when you do autohome when it goes thru to do the endstops it will center on the center of the bed after it does the z probe of the bed . when i click mesh it starts in the middle of the bed . how do i get it to start at the corner like it should
were would that info be what files do i need to post ?its the drop down menu for the mesh compensation.
Here is something to get you started. It's not exactly the way I do it but it works.
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
Do you have a bed.g file? That may ultimately be what you're running from the drop down.
this is in the bed g file
; bed.g
G29 ; probe the bed and enable compensation
Where are the endstops physically located?
Does -X move to the left, +X to the right?
Does -Y move the nozzle to the front of the bed and +Y to the back?
Is the Y axis really only 170mm long and the X is 200mm?
oki set it to 170 becasue it would try to keep going but i now find out that the y is moving more than it should
10mm is 13mm when it moves so i need to adjust the steps ?
You'd have to do the calculation knowing your belt tooth pitch and pulley tooth count as well as stepper resolution and microstepping, but I think your correct steps for X and Y is actually 80.
xy_steps_per_mm = (motor_steps_per_rev ∗ driver_microstep) / (belt_pitch ∗ pulley_number_of_teeth)
