SOLVED X is going the wrong way?
I'm setting up my D-bot and everything was going swimmingly. I was just setting the Z-offset for my BL Touch. Now the X is going the wrong way. I have the motor going forwards and the Enndstop low but now when I home the X it starts going towards the high end. What I can't understand is that this was working until I issued a G92 Z0.
Can any see anything in my config that might explain this? I have even reloaded the config from the config.zip and it still does it.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Jul 24 2020 19:53:55 GMT+0100 (British Summer Time); General preferences
M550 P"CoreXY" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X700 Y700 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X270 Y270 Z320 S0 ; set axis maxima; Endstops
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
G31 P500 X150 Y150 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
It is a funny story. I don't know how but my setup changed from a CoreXY to being Cartesian. So when I told it to move it was only turning 1 stepper at a time. I am still totally in the dark as to how it happened.
Just a note, if I swap the X so that it drives backwards
M569 P1 S0then instead of the head moving in the X, it moves in negative Y
I tried to delete this but it doesn't look as if I can.
I assume you've solved the problem? How bout post the solution and leave it for future generations to find?
I think it's preventing you from deleting it because you've already replied to yourself.
But if you'd really really rather just delete it all let me know and I will remove it entirely.
