Heater, Thermistor and Fan for Mosquito Magnum
  • Good Morning,
    just assembling my first CoreXY and thinking about which heater, thermistor and fan to use for a Mosquito Magnum hotend. I'm using a Mosquito on my CR-10S Pro and had problems with controlling the original fan so I think i'll go with a different one. But what's about the heater and thermistor. Is it wise to use the original ones from Slice Engineering or can someone recommend something different?
    Thanks, Martin
  • The Slice engineering 50w heater and thermistor are very well constructed. That little hotend heats up like nobodys business!
    And for a fan, I am using a three wire to monitor RPMs.
    So far the toolboard seems to handle it all great. From past experience, I find that going with the name brand gear is worth the time, hassle and aggravation save from not going with knockoffs.
  • Hello, I went for a 25mm fan, knockoff 450deg thermistor and 22mm 50W cartridge from mellow.
    Even running their hardened and plated copper nozzles
    Absolutely no issue with setup or reliability it's been doing a great job for the past 3months here.
    I found the ambient temp shows up rather high but the discrepancy goes off as it rises in temp; from the 200s deg it's spot on. (controlled with a temp probe inserted in the hotend)
