    Config tool: wrong paramater for thermostatically controlled fan
    Firmware wishlist
    • Leavundefined
      Leav
      Again, please let me know if there is a better place to post this.
      This could be a bug in the firmware, but I think the firmware is functioning correctly and it's just a misunderstanding/bug in the config tool.
      In the configurator, when limiting the fan speed in a thermostatically controlled fan, the output is incorrect:
      Actual output - S0.25 (This does not control or limit the fan speed) :
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0.25 H1 T45                           ; set fan 0 value. Thermostatic control is turned on
      Correct output - X0.25 (this does limit the fan speed) :
      M106 P0 X0.25 H1 T45                           ; set fan 0 value. Thermostatic control is turned on
        I thick your expectation of what the config tool should be providing is accurate to what it is actually providing. In other words, I believe it's always used speed % as the S parameter and not the X parameter. It's just not advanced enough to setup more complex configurations like that.
        The config tool is asking what speed do you want the fan to come on at, nothing more.
        • Leavundefined
          Leav
          @Phaedrux said in Config tool: wrong paramater for thermostatically controlled fan:
          Perhaps I am misunderstanding, but when E0 reaches 45 degrees, it turns it on at 100%, not 25%.
          I think the S parameter sets the instantaneous speed when sending an M106 command, but is ignored when the fan is thermostatically controlled (my experience at least, may be wrong)
