Duet 2 wifi CR10 end stops not working
@Smedley said in Duet 2 wifi CR10 end stops not working:
The M203 I messed it up cannot get it back to the 500 it was set to.
see if you have a more than one M203 line, espescially if you also have a config-override.g file.
and ignore the LEDs on the board, in duetwebcontrol go to the settings -> machine specific page and look at the end stop status as you manually trigger each one. if the status doesn't change when you actuate the endstops then they will not stop the motor either. as suggested above pay attention that it is the correct endstop status that changes.
if you've wired according to the slikscreen on the board the mapping between the driver and endstop indexes and letters should be as follows
x=0
y=1
Z=2
e0=3
e1=4 -
@Phaedrux
Thank you I found a wire crossed.Thanks to all that helped me. Greatly appreciate all the help.
Dave
