Bltouch which Wiring diagramm ?
  • Hi
    i have the Creality Bltouch but i dont know which wiring diagramm i shoud to use.
    Bltouch is only blinking in red
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
    at this moment i have wired all in Z-Probe like this:
    Black/Blue - GND
    Red - 3,3V
    White - z_probe_mod
    yellow - Z_probe-in
    my config :
    M307 H3 A-1 C-1 D-1
    M558 P9 C"^zprobe.in" H5 F500 T4000 R1 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
    M950 S0 C"exp.heater3"
    G31 X42 Y5 Z0 P25
    M557 X20:220 Y20:220 S65                       ; define mesh grid
    M376 H20
    deployprobe.g
    M280 P0 S10
    retractprobe.g
    M280 P0 S90
  • i have change now to Heater 7 M401 and M402 is working
    but now i cant home my axes , i have post my configs and homeall and homez,my bed is 220x220
    my 0,0 is in the right corner, i have a Ender5
    config.g
    M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
    ;M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
    M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
    M307 H7 A-1 C-1 D-1
    M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
    M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
    G31 P50 X42 Y5 Z1.5 P25
    M376 H20
    homeall.g
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 Z5 F6000 H2 ; lift Z relative to current position
    G1 H1 X515 Y515 U-515 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 X-5 Y-5 U5 F6000 ; go back a few mm
    G1 H1 X235 Y235 U-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X110 Y110 F6000 ; go to first bed probe point and home Z
    homez.g
    ; homez.g
    ; called to home the Z axis
    T1
    G1 X110 Y110 F6000 ; go to first probe point
  • Moderator
    @lui2004 said in Bltouch which Wiring diagramm ?:
    M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
    Change that to
    M574 X2 S1 P"xstop"
    M574 Y2 S1 P"ystop"
    0,0 is the front left corner. The homing position on the Ender5 is the rear right, but that doesn't need to be the 0,0 origin point.
    I don't understand why you homeall has a U axis.
    You haven't posted enough of your config.g to udnerstand.
  • i have made some changes and hope that now its all fine or what i can do better ?
    config.g:
    ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
    G90                                      ; Send absolute coordinates...
    M83                                      ; ...but relative extruder moves
    M550 P"Ender 5"                          ; Set machine name
    M552 S1                                  ; Enable network
    M587 S"WLAN-***" P"3***************0"                 ; Configure access point. You can delete this line once connected
    M586 P0 S1                               ; Enable HTTP
    M586 P1 S0                               ; Disable FTP
    M586 P2 S0                               ; Disable Telnet
    M569 P0 S1                               ; Physical drive 0 goes forwards
    M569 P1 S1                               ; Physical drive 1 goes forwards
    M569 P2 S0                               ; Physical drive 2 goes backwards
    M569 P3 S0                               ; Physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                               ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                 ; Configure microstepping with interpolation
    M92 X80.00 Y80.00 Z800.00 E411.53        ; Set steps per mm
    M566 X600.00 Y600.00 Z60.00 E300.00      ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z500.00 E6000.00  ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E5000.00    ; Set accelerations (mm/s^2)
    M906 X800.00 Y800.00 Z800.00 E800.00 I30  ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30                                  ; Set idle timeout
    M208 X0 Y0 Z0 S1                         ; Set axis minima
    M208 X220 Y220 Z300 S0                   ; Set axis maxima
    M574 X2 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
    M574 Y2 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
    M307 H7 A-1 C-1 D-1
    G31 P25 X-42 Y-5 Z5.200
    M557 X15:215 Y15:195 S20                       ; define mesh grid
    M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                        ; map heated bed to heater 0
    M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 B0 S1.00
    M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
    M563 P0 D0 H1                            ; Define tool 0
    G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
    G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
    M501
    M575 P1 S1 B57600
    homeall.g
    ; homeall.g
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:12 GMT+0200 (Mitteleuropäische Sommerzeit)
    G1 H2 Z5 F6000          ; lift Z relative to current position
    G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000       ; go back a few mm
    G1 H1 X-225 Y-225 F360  ; move slowly to X and Y axis endstops once more (second pass)
    ;G91                    ; relative positioning
    ;G1 Z5 F100             ; lift Z relative to current position
    ;G90                    ; absolute positioning
    homez.g
    ; homez.g
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:37 GMT+0200 (Mitteleuropäische Sommerzeit)
    G90 				; Make sure we are in absolute mode
    G1 Z10 F6000 		; Rapidly move the Z axis to Z=10.
    starting script S3D:
    G28 XY ; Home
    M561 ; Clear any bed transform that might be in place
    G1 X110 Y110 ; Move Probe to middle of bed
    G30 ; Do a single probe
    G1 X5 Y10 Z0.2 F3000 ; get ready to prime
    G92 E0 ; reset extrusion distance
    G1 X160 E15 F600 ; prime nozzle
    G1 X180 F5000 ; quick wipe
    ending script:
    G28 X0 Y0 ; home X axis
    M106 S0 ; turn off cooling fan
    M104 S0 ; turn off extruder
    M140 S0 ; turn off bed
    M84 ; disable motors
  • @lui2004 Someone else who can't get it to work on heater 3 , but works first time on heater 7 !!!
  • it will dont work an Heater 3 i dont know why!
    i spent 1 day to make it work but no chance.
    on Heater7 in 5 minutes i have made my config it will works fine
  • thats odd, afaik there is a difference between the outputs on the Duet3, but all the Duet2 outputs (except lcd and chip select pins) support PWM as needed for servo/bltouch?
    maybe dc42 has some insight to offer?
  • Moderator
    Delete these lines in config.g:
    M587 S"WLAN-" P"3************0" ; Configure access point. You can delete this line once connected
    M587 in config.g is a security hazard, and writes parameters to WiFi chip every restart, which will eventually wear out the flash memory. See note at end of https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
    M307 H7 A-1 C-1 D-1
    You don't need this line when using RRF3, only in RRF2.
    If you're only using the probe for Z homing, replace this with M574 Z0. See the last Note here https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M574_RepRapFirmware_Num_3
  • Last question 😉
    i have this Stepper motor as Extruder motor after 20 minutes of print it was really hot:
    thats my config for E:
    https://www.amazon.de/gp/product/B07TXD7ZCF/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
  • Moderator
    How hot is really hot? Small pancake steppers like that don't have a lot of thermal area to dissipate the heat, so running hot is to be expected. The motors themselves can handle far more heat than it would be comfortable to touch for more than a second without issue.
    That link seems to indicate that the motor has a max current limit of 1000ma and you are using 800ma which is 80% which is within the recommended range. You can try to lower it to 600ma, but you may lose some torque which the pancake doesn't have in spades to begin with.
    Adding a heatsink to the motor might not be a bad idea if you're concerned about a plasting mount softening. You can get NEMA17 sized heatsinks pretty cheaply.
    https://www.amazon.de/s?k=nema+17+heatsink&i=industrial&__mk_de_DE=ÅMÅŽÕÑ&crid=1DPBOAFV7I9CF&sprefix=nema+17+heat%2Cindustrial%2C286&ref=nb_sb_ss_i_1_12
  • Moderator
        ; homeall.g        ; called to home all axes        ;        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:12 GMT+0200 (Mitteleuropäische Sommerzeit)        G91                     ; relative positioning        G1 H2 Z5 F6000          ; lift Z relative to current position        G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)        G1 H2 X5 Y5 F6000       ; go back a few mm        G1 H1 X-225 Y-225 F360  ; move slowly to X and Y axis endstops once more (second pass)
    Does your homeall actually work? You've got the endstops marked as being at the high end of travel, but the homeall moves towards the negative side. The homeall should be moving towards the positive. If the motor isn't moving the correct direction, you'll need to change the direction of rotation in M569 for those axis.
  • yes have changed it all,works fine.
    Only extruder motor is hot if print i dont know why.
