infill idea maker
  • Hi everyone, I am trying idea maker with standard profiles taken from the library but I am having some problems with the infill which seems under extruded. Even if you reduce speed and increase flowrate, the problem persists.
    Before I used prusaslicer and everything was fine, I don't understand if it is a duet configuration problem or if it has some small bug idea maker. Do you also have this problem?
  • Moderator
    Sounds like the cause would be in the slicer area. The firmware doesn't have a concept of infill.
