Duet wifi connection issues
Hi Guys hoping you can help.
I have been using the duet wifi for some time with no issues but recently I have been unable to get it connected to the wifi.
The chip used to flash blue when connecting this no longer happens. I have tried updating to the latest firmware still no luck.
When I sue M552 S0 followed by an M552 I get a message informing me that "Network is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0" this is the same as M552 s1 but instead of network disabled it reads network enabled.
I have tried yo clear the saved network information using M588 s"*" but that responds with the message "Error: M588: No WiFi interface available". something I have been able to find in any other threads.
Any help would be appreciated I have provided a copy of M122 Diagnostics below.
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6JKD2-3S86Q-K9DYN
Used output buffers: 1 of 24 (1 max)
Static ram: 27980
Dynamic ram: 91884 of which 20 recycled
Exception stack ram used: 256
Never used ram: 10932
Tasks: NETWORK(ready,1980) HEAT(blocked,1456) MAIN(running,2300) IDLE(ready,80)
Owned mutexes:
Last reset 00:10:16 ago, cause: software
Last software reset at 2020-07-31 16:35, reason: User, spinning module GCodes, available RAM 8496 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 24.3, current 24.6, max 25.2
Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 1162930394
Slowest loop: 59.49ms; fastest: 0.08ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.4ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122 " in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1.02ms; fastest: 0.00ms
HTTP sessions: 0 of 8
Interface state establishingLink, link down
Is that the whole M122? Seems to be missing a part of the Wifi?
I.e. something like:
... === Network === Slowest loop: 203.13ms; fastest: 0.08ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 2 WiFi firmware version 1.23 WiFi MAC address ac:3a:bc:5e:35:8a WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25784 WiFi IP address 10.10.0.196 WiFi signal strength -59dBm, reconnections 1, sleep mode modem Socket states: 0 0 0 0 0 0 0 0
That is the whole 112 that is returned
Weird. It's like it doesn't see the wifi module at all anymore.
Can you try flashing the wifi module?
Download this file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWiFiServer-1.23.bin
Rename it to be just
DuetWiFiServer.bin
and place it on the SD card. Boot it up over USB and send M997 S1 to try and flash the wifi module.
I have tried flashing already but will try again tomorrow morning, also a bit of added behaviour that I forgot to mention, every now and again after turning on and off the WiFi will work without any issue, probably one in 20 times (on/off).
Again will try to flash tomorrow morning and see if it makes any difference.
if you can get a close up of the wifi module solder joints that might be interesting to see. (best approach might be one picture from either side, good ambient lighting and in focus)
@Phaedrux
So I have re flashed the wifi module again this morning and it worked! I tried this several times yesterday with no success but this time every thing worked as expected and I'm once again connected to wifi. I guess this will be one of those times where I will never truly know what went wrong. Thanks for the help.
