    Random number generation with Meta Commands?
    Gcode meta commands
    304
    • Kolbi
      Kolbi last edited by
      Hi all,
      I was trying to make a simple random number generator - single digit, -9 to 9 numeric swing and came up with this:
      echo floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))
      Is there a better way to do this?
      Cheers,
      Kolbi
        What's the use case? We could add a random number function if it would be generally useful.
        Kolbi engikeneer 2 Replies Last reply Reply Quote 1
        • Kolbi
          @dc42 As of now I'm using it to offset prime line and working on making it used to offset prints starting location on the build plate.
          • Kolbi
            Kolbi @dc42 last edited by
            Sorry @dc42, use case posted here: https://forum.duet3d.com/topic/17872/automatic-bed-leveling-with-conditional-gcode-iterations/62
            Cheers,
            Kolbi
            • Kolbi
              Kolbi last edited by Kolbi
              Or to make a R2D2 impression...
              while iterations <= 4                            ; perform 5 passes
                 M300 S{3000+(200*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))} P{200+(10*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))}
                 M300 S{3000+(200*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))} P{100+(10*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))}
                 G4 P200
              • engikeneer
                engikeneer @dc42 last edited by
                @dc42 jumping on this one, I would find it quite useful if I could slightly randomise my z home position. I use a piezo nozzle contact to home Z and I have a ziflex magnetic build surface. I find that over time my Z-offset is drifting because repeated probing of the same point is putting an indent in the surface and damaging it.
                I'm thinking if I could randomise the probing point within a given area (say a 10mm square) it would give me much less wear on the ziflex and shouldn't impact my z homing accuracy too much (by being in nearly the same place)
                i3 clone with a bunch of mods
                • mrehorstdmd
                  mrehorstdmd last edited by
                  I would find it useful for randomly selecting pattern files to run on my sand table.
                  • Kolbi
                    @dc42, here's the primeline macro - use case:
                    ; 0:/sys/primeline.g
                    ; Print prime-line at a 'randomized' Y positon from -1.1 to -2.9
                    G1 X0 Z0.6 Y{-2+(0.1*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))} F3000.0;
                    G92 E0.0                                                   ; set E position to 0
                    G1 Z0.2 X100.0 E30.0 F1000.0                               ; prime line
                    M400                                                       ; finish all current moves / clear the buffer
                    Cheers,
                    Kolbi
                      I've added a random(nnn) function to the expression evaluator, where n must be a positive integer. It returns a random integer in the range 0 to nnn-1. It will be in the 3.02beta releases.
                      Kolbi 1 Reply Last reply Reply Quote 0
                      • Kolbi
                        @dc42 said in Random number generation with Meta Commands?:
                        Nice! Is there a list of new expected features?
                          dc42 administrators @Kolbi last edited by
                          @Kolbi said in Random number generation with Meta Commands?:
                          You can see what is already implemented or partly implemented at https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
