    M28, writing file with comments possible?
    170
    • Kolbi
      Kolbi last edited by Kolbi
      UPDATE: BLUF, M28 "0:/macros/test" will create the file 'test' in the directory 'macros' but any lines beginning with comments ';' will be ignored. M559 can replace the command M28 and allows the comment lines to be written to the file, but the command differs in that it requires a 'P' before the file name such as: M559 P"0:/macros/test"
      If using the M559 command, ensure you use the P - else your config.g in /sys/ will be overwritten.
      In using the M28 command, I just realized that my expected comments in the file to be written are ignored - example follows.
      Using the following:
        M28 "0:/macros/test"                                           ; Begin writing to SD card file
        ; 0:/macros/Heat Nozzle
        ; Heat nozzle to set temp
        M291 R"Filament Handling" P"Heating nozzle for PETg, please wait." S0 T5
        T0                                                             ; Activate Hotend
        M109 S230                                                      ; set temp to 230c and wait
        M29                                                            ; Stop writing to SD card
      Results in this file:
      Is it possible to retain the comments, to get the following result?
      Thanks,
      Kolbi
      • A Former User
        Look at M559 instead? (i posted to a recent thread on the topic with a caveat, and its only usable over usb, if you need it self contained then no-go)
        Kolbi 1 Reply Last reply Reply Quote 0
        • Kolbi
          Kolbi @Guest last edited by Kolbi
          @bearer said in M28, writing file with comments possible?:
          Most definitely a no-go...
          When executing the following:
            M559 "0:/macros/test"                                           ; Begin writing to SD card file
          It resulted in:
          M98 P"0:/macros/Maintenance/test"
          Writing to file: config.g
          And - it most definitely overwrote my config.g 😭
          ...always have a backup☺
          A Former User 2 Replies Last reply Reply Quote 0
          • A Former User
            A Former User @Kolbi last edited by
            @Kolbi said in M28, writing file with comments possible?:
            probably, not sure if its reliant on a stream like usb or telnet, but there does seem to be an issue where it only works with a known filesize (if you dig up the other tread from not too long ago).
            but given that the parser is meant to ignore anything after a ; you'd need to find a way to escape the ;
            woraround may be to use echo or M118 to telnet, uart or usb which if not in use will have no effect other than being human readable in the file?
            • A Former User
              thats expected, as config.g is the default filename if not specified with the P"filename" parameter.
              • Kolbi
                Ah!!!!! The 'P' - I forgot the 'P'
                It works! Used the following:
                  M559 P"0:/macros/test"                                           ; Begin writing to SD card file
                And it made the file:
                • A Former User
                  thats interesting, seemed to not work with M29 from USB.
                  which version of RRF you on?
                  • Kolbi
                    @bearer Running 3.1.1
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                    But also, I'm not running from USB. Running a macro, to make another macro.
                    • Kolbi
                      Top post edited with BLUF.
