    12V fan output
    • Jaranundefined
      Jaran
      Hello! Recently my 24V part cooling fan stopped working. I have several 12V fans laying around, but im out of the 24V ones. I saw in the documentation that you can use a buck converter to give 12V to the V_Fan connector.
      I have tried to do this, but for some reason I can't get any power output at the fan pins. I have a buck converter supplying some other fans and LED's. I have meassured the voltage output from it and its at about 11.8V. Im using the fan on the FAN1 output. No other fans are connected to the fan connectors.
      I wired the 12V(+) to the connector as shown below(Yellow arrow):
      Is there anything im missing here?
      • A Former User?
        A Former User @Jaran
        @Jaran said in 12V fan output:
        that should be correct, and you also have a common ground for the Duet and the buck converter presumably?
        • Jaranundefined
          Jaran
          Oh, that might be the problem! 🤠
          I have two PSU's in my printer setup, and the buck converter and the duet is not on the same. So the ground is not from the same PSU. I honestly didn't think much of it when I wired it up, but if thats the issue ill wire up another converter on the same PSU. Ill post back soon 🙂
          Update: Thanks for pointing that out. It works now, but it seems like the two spare buck converters I have is bricked. They both ooutput right below 18V.
            dc42 administrators @Jaran
            Do they have voltage adjustment pots?
            Jaranundefined 1 Reply Last reply Reply Quote 0
            • Jaranundefined
              Jaran @dc42
              @dc42 I have it working now, but yes, they sure did! Been a while sinse I sat up the first one. It has a LCD display where you can dial in the voltage and then adjust it with the voltage pot. I might have done something wrong, but I ended up with 5V on the display as output when I actually reached 12V output while adjusting the voltage adjustment pot.
              Thanks though!
