Install DSF on a Kernel <4.8 | GPIOCHIP missing
Is there a way to get DSF running on a raspian with Kernel 4.4? I´ve got a banana pi with raspian installed. But the newest kernel is 4.4.
Best
@PCR Unfortunately this is not possible. Early versions of DSF did instead rely on
wiringpi
but that turned out to be too unstable so a conversion to Linux GPIO driver that was available from Linux 4.8 was done.
ah ok what a bummer. But understandable.
Hopefully bananpi release a raspian version with 4.8....
i now installed armbian. with a newer kernel! Thanks to @jay_s_uk for pointing me to this!
enabled spidev, changed buffer size etc. But know i have this error
[fatal] Could not connect to Duet (Error 517. Cannot put line into event mode.)
What could this be
@PCR said in Install DSF on a Kernel <4.8 | GPIOCHIP missing:
seems the pin does not support interrupts?
you can change pin in /opt/dsf/conf/config.json
