FLSUN QQ-S Pro - json file request.
  • Hi All.
    Just swapped out my FLSUN QQ-S Pro board for a Duet 2 Wifi. Not quite going according to plan. Although the magic smoke is still in all of the components so the board is still working.
    Does anyone have a config.json file I can run through the online configuration tool to see what I've got wrong. I'd be happy with one for a QQ-S if you don't have a Pro version.
    In fact at this point, I'd be happy with one for a QQ 😞
    Stay safe all.
    Pete.
  • Moderator
    Does this help at all?
    https://forum.duet3d.com/topic/15468/flsun-qq-s-pro-config?_=1596644091957
    You should be able to get a pretty decent basic config going through the customizer. If that thread doesn't get you what you need, let us know where you get stuck in the configurator.
  • Thanks for the response. I'd seen this one, I've gone through it and have found some additional information. I'll spend some more time and then come back with more direct questions. It seems to be the levelling sensor that remains a problem for some, ah well, it'll be worth it in the end.
    Regards,
    Pete.
  • @PeteL did you manage to get it up & running?
    I'm in the same shoes, but I'm not sure where it's going wrong...
    Any help would be appreciated!
  • I have a Q5 which works perfectly!
  • @PCR could you share your config.json file?
  • Can Share my config.g
    Keep in mind that its not for a duet. You have to Change the probe Pin i think
    code_textGeneral preferences
    G90                                            ; send absolute coordinates...
    M83                                            ; ...but relative extruder moves
    M550 P"Flsun Q5 Delta"                             ; set printer name
    M665 R105 L215 B100 H200                      ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
    M552	S1                               ; enable network and acquire dynamic address via DHCP
    M586 P0 S1                                     ; enable HTTP
    M586 P1 S0                                     ; disable FTP
    M586 P2 S0                                     ; disable Telnet
    M569 P0 S1 D3 V26                                  ; physical drive 0 goes forwards using default driver timings
    M569 P1 S1 D3 V26                                    ; physical drive 1 goes forwards using default driver timings
    M569 P2 S1 D3 V26                                   ; physical drive 2 goes forwards using default driver timings
    M569 P3 S1 D3 V26                                   ; physical drive 3 goes forwards using default driver timings
    M584 X0 Y1 Z2 E3                               ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z80.00 E502.74               ; set steps per mm
    M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
    M201 X1200.00 Y1200.00 Z1200.00 E1000.00       ; set accelerations (mm/s^2)
    M906 X1300 Y1300 Z1300 E1000 I30                ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                        ; Set idle timeout
    M208 Z0 S1                                     ; set minimum Z
    M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
    M574 Z2 S1 P"zstop"
    M558 P8 C"!^xstopmax" H3 F120 T6000             ; set Z probe type to switch and the dive height + speeds
    G31 P500 X0 Y0 Z19.983                            ; set Z probe trigger value, offset and trigger height
    M557 R100 S20                                 ; define mesh grid
    M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
    M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                        ; map heated bed to heater 0
    M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
    M950 F0 C"fan0" Q100                           ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"e1heat" Q100
    M106 P1 S1 H1 T50 B1
    M563 P0 D0 H1 F0                               ; define tool 0
    G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
    G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
    T0                                             ; select first tool
    M501
