UNSOLVED M675 probe cavity issues
Hi, I am hoping someone can help me with this. I can probe on xyz using m585 with configured endstop, but i cant get m675 to work. This is what my macro looks like,
G91
T1
M675 X10 E3 L0 R2 F500When I run the macro the machine starts moving in the -x direction and when i trigger the end stop nothing happens. It wont stop moving on the -x direction until i hit the e stop.
This is my config.g file
; Configuration file for factory testing Duet Ethernet and Wifi with V2.02 firmware
; generated by RepRapFirmware Configuration Tool v2.1.4 on Wed Dec 18 2019 20:29:17 GMT+1100 (Australian Eastern Daylight Time); General preferences
M550 P"cnc" ; set printer name
M453 ; cnc mode; Network
M552 S1 ; enable network
M552 P192.168.0.60 ;
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes forwards
M569 P3 S0 ; physical drive 3 goes backwards
M569 P4 S1 ; physical drive 4 goes backwards
;M584 X0:3 Y1:4 Z2 U3 V4 P3 ; set drive mapping
M584 X0 Y1:4 Z2 V4 P3 ; set drive mapping
M350 X16 Y16 Z16 U16 V16 I1 ; configure microstepping with interpolation
M92 X643 Y643 Z400.00 U100 V643 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 U600.00 V600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X3000.00 Y3000.00 Z249.60 U2000.00 V3000.00 ; set maximum speeds (mm/min)
M201 X50.00 Y50.00 Z20.00 U50.00 V50.00 ; set accelerations (mm/s^2)
M906 X2200 Y2400 Z2400 V2400 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z-80 U0 V0 S1 ; set axis minima
M208 X555 Y410 Z80 U410 V410 S0 ; set axis maxima; Endstops
M574 X2 S1 C0 ; set active low and disabled endstops
M574 Y2 S1 C1 ; set active low
,M574 Z1 S0 C2 ; set active low
M574 Z2 S1 C2 ; set active low
M574 U1 S0 C3 ; set active low
M574 V2 S1 C4 ; set active low; Heaters
M140 H-1 ; disable heated bed; Tools
M563 P1 D0 ;; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off;
M98 Pcustomconfig.g ;
T0 ; select first tool
; M117 Use https://configurator.reprapfirmware.org/ to set up your printer com
@kouta10 said in M675 probe cavity issues:
I don't think X10 is correct. It should just be X to denote the X endstop. Not sure where you got L0 and E3 from either.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M675_Find_center_of_cavity
@Phaedrux if i got my x end fixed at low end of axis, how does that work? If cavity is in the middle of the bed, x never gets triggered.
The hole idea is to use probe as trigger for cavity, i don't see how that works any other way unless i understood it wrong.
Did you correct your M675?
I'm not sure I understand what you mean.
