SOLVED Thermistors in Duet 2 FW 3.x
I have recently made the switch to the FW3 on my Duet v2 ....
And now I'm configuring it, today it's Thermistor ... and it's a question about the thermistor on the bed, the DWC reads a strange temperature, 273.1 Cº .... and of course, when the ambient temperature is 32 ºC, it seems strange to me ...
I attach the thermistor configuration in "config.g", by default in the web configurator ...
M308 S0 P "bedtemp" Y "thermistor" T100000 B4138 R4700 ; M305 P0 T100000 B4350 R4700 configure sensor 0 as thermistor on pin bedtemp
M950 H0 C "bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M308 S1 P "e0temp" Y "thermistor" T100000 B4138; configure sensor 1 as thermistor on pin e0temp
M950 H1 C "e0heat" T1; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limitHere I put the configuration that I had with the FW 2.x, with which it was working ...
M307 H0 B0 S1.00 ;Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4350 R4700 ; M305 P0 T100000 B3950 R4700 Set thermistor + ADC parameters for heater 0 M305 P0 T100000 B4138 R4700
M143 H0 S90 ; Set temperature limit for heater 0 to 90C
M305 P1 T100000 B4350 R4700 ; Set thermistor + ADC parameters for heater M305 P1 T82202 B4371 R4700
M307 H1 A312.4 C95.9 D12.8 S1.00 V23.9 B0
M143 H1 S245 ; Set temperature limit for heater 1 to 245CWhat can be?
@peirof said in Thermistors in Duet 2 FW 3.x:
I think the M308 command has failed because there is a space between Y and "thermistor". Try removing it.
Not....
in the config.g file there was NO such space ...
Can I add something else .... I have tried to disconnect the thermistor from the bed ... and DWC, with the bed thermistor disconnected, continues to show the same value -273.1.
It shows the same, if the thermistor is connected than disconnected ...
Let's draw a stupid veil on the matter .....
Well .... it turns out that the connector to the duet board had come loose .... once reconnected .... it seems to work ....
one ask...
in FW v2, when there is some problem with thermistor, DWC show 2000 C.....
Now? -273? or other
I'm glad you found the problem. A disconnected thermistor has always shown -273C in RRF. Other temperature sensor faults give a reading of 2000C.
@dc42 how I can know the kind of temperature sensor? Think its termopar... Different configuration?
Measure the resistance of the sensor at room temperature. If it's a sort used in 3D printing:
<10 ohms: thermocouple
100-120 ohms: PT100
1000-1200 ohms: PT1000
Around 10K: 10K thermistor
Around 100K: 100K thermistor
Around 500K: 500K thermistor
